Question about Watches
Hello I have a DKNY NY3827 Digital watch, i've just had the battery replaced and when it came back the display and buttons were all back to front. The display is up side down and the light button is now the set button and the set button is the light button etc. Is there anyway of reseting these watches.
Open it , take the movement out and turn it 180 degrees to align the face..
I guess you sent it to conman watch maker/repairer cause he got his basics wrong.
Posted on May 02, 2009
What battery is in the DKNY Ny Twist watch?
I had to look into this for my wife's DKNY watch and this particular model has a Ronda 751 quartz movement, which takes a 379 battery. You can verify this by entering the movement name 'Ronda 751' and you'll see pictures of the movement with a 379 battery inserted.
Jan 07, 2014 | DKNY Ny4634 Twist Watch
Swarosvski stone has fallen out
Swarovski has been very responsive to my enquiries in the past. Try them first and DKNY if all else fails.
Mar 31, 2017 | Watches
I bought a DKNY watch for my girlfriend last Christmas and the battery finally died. I have taken it to 2 different jewelers to get a new battery in it and they have both told me that one of the screws...
Have you ried taking it back to the supplier? If it is still under warranty, then they should be willing to replace tha battery and if that is not possible they should replace it.
Dec 21, 2010 | DKNY 1009 Wrist Watch
Hi - I bought a DKNY NY1304 watch three years ago, and unfortunately my digital screen just broke. I was wondering if it is possible to replace it with a new device? The only information given for the...
You have to speak to your nearest DKNY distributor - they might help you and carry out necessary repairs. Alternatively visit your nearest watch repair shop and ask if they can help.
Jul 31, 2010 | DKNY NY1304 Watch for Men
Dkny 1350 how to change day
Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
May 25, 2010 | DKNY 1009 Wrist Watch
Dkny ladies watch winder lost and watch stopped
DKNY is typically a quartz movement and doesn't have a "winder". I believe the part you are referring to is the crown. The watch may have stopped working for several reasons. The first three things I would suspect is that the battery died, the watch is in the set position, or the movement was damaged when the crown was coming off. If the watch is in the set position then pushing the stem in will cause the watch to run. The next thing to do is to replace the battery since it is only a few bucks. If it runs then you can replace the crown and your set. If it doesn't run I would suggest replacing the movement along with the crown and that you will have to price and see if it is within reason since this type of repair wont be covered under warranty.
Depending on the model of DKNY you may have to go through DKNY for the part. Remember that they are manufactured by Fossil. You could save yourself a lot of time by going to your local watch repair shop.
Thanks!
Sep 19, 2009 | DKNY Watches
Replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Dec 15, 2008 | DKNY Women's Crystal Bezel Watch
Replacement battery for DKNY NY1050
I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...
specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment.
The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even.
Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it.
Hope this may help you;
DON'T FORGET TO RATE:
Sep 05, 2008 | Watches
Watches Logo
90 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
