Question about LG Dishwashers
Lg dishwasher displays LE error - LG Dishwashers
  • 17,970 Answers
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
Posted on May 26, 2011
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
LG DISHWASHER, STOPS WORKING AND DISPLAYS LE. WHAT DOES THIS MEAN
LE is a Motor error
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB
Sep 07, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code LE
Hello and welcome,
locked.
locked.
Remedy:
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Hi I have a LG dishwasher model no:LD-12AW2 which is comming up on the display LE any idea what that means Thanks Andrew
Hi
Searched on google and found error code LE was a blocked filter cleaned tested ok
Sep 09, 2008 | LG Dishwashers
LG dishwasher
L2 error code is the same as an LE error code.  You have a problem with the sump motor assembly and needs to be addressed by a qualified LG technician.
Apr 08, 2008 | LG LDF6810ST Stainless Steel Built-in...
LdF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
329 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
