Question about Troy Bilt 5.5hp Self Propelled Mower
Troy built 675 series will not start and has gas . Ive checked the spark plub connection and all is good .
    Scholar:
  • 87 Answers
Have you checked the quality of the gas? is it old from last season? open the gas cap and smell the gas,does it smell like varnish? If your gas is bad it wont start because it has lost it"s flamability.also you don"t what to use old gas because it can damage your engine by causing your valves to stick or freeze up...If your gas is bad you need to drain your fuel tank and carb and replace it with fresh gas..You might want to go and get some fuel stabalizer at the auto store or wal mart and add it to you fuel can you use to fill you mower. That way your fuel will be good for up to a year when stabalizer is added to your gas..Have you checked for a spark at the spark plug? remove the spark plug from the motor, plug the spark plug back into the plug socket and lay the spark plug aganst the muffler, pull the pull start cord and look at the end of the spark plug for a bright blue spark. You might want to do this in the shade to be able to see it. If you don"t see a spark , i would try a new plug first and see..if still no spark then your ignition coil has gone bad,that is the whole unit from your spark plug wire to the coil..check these items first,,,
Posted on May 26, 2011
I have a troy built trimmer model # tb65ss
check the kill switch position and wiring, if good, check magneto wire
Jun 30, 2014 | Troy Bilt Tb70ss Gas Trimmer
If I haven't added Stabil to the gasoline for my Craftsmen 675, will that keep it from starting?
Ethanol gas can gum up the fuel system if left in unit for to long from now on use ethanol free gas in all small engines
Jun 22, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
Troy bilt lawn mower were spark plugs go in striped and wont tighten
you can get a spark plug thread repair kit at a auto parts store
Aug 12, 2012 | Garden
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
I have a Troy Bilt 675 lawn mower, won't start.
is the gas in the tank old? if so, try to drain it and put fresh gas in. Pull the spark plug to make sure it is not fouled and replace it or put in a new one. Check to make sure that you do not have the mixture or choke set to run too rich or too lean. If you are at an altitude above 2,500 feet you need to run more lean to compensate.
May 30, 2010 | Troy Garden
Lawn mower
Always start by checking the spark plug. If you are getting spark and still not starting, it's probably a carburator problem.
May 06, 2010 | Troy-Bilt Pony Garden Tiller
Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Apr 17, 2010 | Garden
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
707 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
