Question about ASUS P5RD1-VM Motherboard
Find sata raid controller
Same a problem...where can get sata raid controller?
  • aivenleong Aug 16, 2008
    i wanna find sata raid controller
  • djpout Nov 16, 2008
    Asus seem to ignore that someone can need the support drivers for raid (the ones we put on a floppy for F6 when installing Windows XP)
    So, this is the second motherboard from asus make me sick about searching it!!
    I searched directly with the chip number, and found it after 2 days of research. But now i can't find anything for the P5RD1-VM. &$%*$&%
Put file update and run it and check you setup motherbord ATA install or not
Posted on Sep 23, 2008
How do you turn on the SATA controllers for this board? By this I mean how can you put the SATA connections and their drives into the boot order? I can't see this option in the BIOS only to enable the...
SATA Controllers are always on. you can't disable or enable it.
RAID and SATA are two different subjects and they are not dependent each other.
so if you got a problem with your motherboard explain it clearly.
Jan 12, 2011 | MSI K8N NEO2-Platinum (MS7025) Motherboard
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
XP is Not Recognizing Sata H.D. and I Need a RAID Controller Driver
This one should be right for you, remember to put it on a floppy, since XP needs a floppy for a 3rd party driver during install.. good luck!
http://download1.msi.com/files/downloads/dvr_exe/sis_sataraid_floppy_mb.zip
Jun 02, 2009 | MSI 661FM3-V Motherboard
RAID 0 on Asus motherboard
Hi macjax,
I agree Asus wasn't using their noodle when they came up with that one. With the JMicron Controller your sort of forced to use an external for raid. But getting another Raid controller is simple. I like High Point Rocket Raid, and it's simple to install and setup. HERE's a link to there site. The main reason that they should be using an external is for hotswapability. But for some reason JMicron wanted to allow for more drives. Can you image having for external drives!!! Crazy.
Anyway, if you get another controller card, you'll go through needing to load the drivers and change Bios to accept them, and at the same time you can disconnect the JMicron raid. As far as speed is concerned, you're still on the SATA platform, I find no difference on speed unless you have two drives of different sizes.
Good Luck
Mark
Please provide a rating based on this solution.
Thanks
Mar 28, 2009 | ASUS Computers & Internet
Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
Cannot install winxp
I am aware your motherboard has just two sets of sata pins ( only two hard drives can be used )
Have you flashed your bios to latest one ?
Sure your cables for sata are not damaged ?
Are you sure the sata drives are in working order ?
Aug 07, 2008 | ASUS P5S800-VM Motherboard
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
I cant install my hdd sata
Under many cases, the default settings for additional onboard SATA/RAID controller could have been set to [Disabled] when delivered. This will cause the controller to stop its function completely. Suggestion: Please refer to your user’s manual for detailed description on how to enable onboard SATA/RAID controller via adjusting jumper or BIOS settings. Clean SATA cable with a couple cotton sticks lightly dipped into alcohol. If you sitll can not see the SATA drive from within the bios your onboard SATA/RAID controller is defective. Contact Asus tech M-F eastern time at: 812-282-2787. Tech will assign you a case number. Tech will than connect you to the RMA department for replacment/repair.
Jan 09, 2008 | ASUS K8V-MX Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
ASUS P5RD1-VM Motherboard Logo
205 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
