Question about Dehumidifiers
My ela dd822 is plugged in but alll it says is alarm
After I emptied drawer I could get humidifier to work.
Try first unplugging power cable for ten miutes or so, if it does not work, check if the bucket is full.
It has a sensor inside that can also be faulty.
Sep 13, 2008 | NewAir AD-40A Dehumidifier
Our dehumidifier seems to be working fine but the orange light is flashing above the star mark
When an error occurs, the Alarm lamp flashes orange. Check the status of the lamps, then take the appropriate action in Alarm Lamp Flashes or ON Lamp and Alarm Lamp Flash Alternately.
Jan 10, 2017 | Dehumidifiers
I plug it up display shows 8.8. and goes blank. Power light on top and side is green ON. Full bucket light and alarm works, timer button works, nothing else works.
Hello Ethan, thanks for your submission!
Based off what you have described your Frigidaire dehumidifier is displaying 8.78 after being plugged in. This could be an internal issue with a sensor or panel. You may need to contact your manufacturer for additional assistance. Good luck! -Matt
Apr 27, 2016 | Frigidaire Fdl50s1 Air Purifier &...
I have a neostar dehumidifier that is approximately 2 years old. All of a sudden it has stopped working. the alarm led comes on as soon as i switch it on. i have cleaned the filter, i don't know what i...
the red light is for the collection bucket full switch , this is either a true or false condition , both require removal of the bucket and emptying and reseating it propely in its place
Feb 07, 2015 | Dehumidifiers
The clean filter light on my Garrison dehumidifier and I took off the side grills and attached was a mesh screen....I cleaned them and the light is still on.....the interior grills don't seem
the filter minder needs reset after you clean filter everytime Hold down for 5 seconds on button right next to light this should clear alarm
Oct 12, 2014 | Dehumidifiers
Why is my ebacnot working blue light comes on then goes of and red light comes on why
the units self testing and it takes a moment to ck that everything is ok , red light ind. it;s found a problem , ck simple things first , empty bucket, ck float sensor inside bucket ck for Level (gravity) ck filter for cleaning and reset filter alarm if present , then move on to more difficult things like is something wrong with cooling fan or did water get inside and dammage something
Oct 10, 2014 | Dehumidifiers
When turned off, makes a humming sound which it never did before. Can I ignore or do I need to fix some?
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FAD704TDP, is making a humming sound, when it is turned off. I also see that you have tried cleaning the filter and grill already, and want to know if there you should be concerned about this. You should not be alarmed by this. Providing, your dehumidifier is doing what it is supposed to do, and is taking moisture from the air, your appliance sounds like it is working fine. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire FAD704TDP Dehumidifier
Water full alarm
Hi, There should be a little actuating rod poking down from the roof of the bucket chamber which contacts the bucket-float at one end and a microswitch at the other. The microswitch
must be activated to make the compressor and fan run.
Check this if you can to see whether this rod or lever is present, absent, lying on the floor or just plain stuck. If it is stuck in the "full" position then you'll probably have found the problem.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to
help you further. Cheers, D
Jul 10, 2008 | Danby DDR401 Dehumidifier
Control panel lights up-nothing else happens
first check that the bucket is in properly. then remove bucket and push red button with finger with the unit on. if you are still getting a red alarm light it might be time to change the control panel. also unit does not work the same in cold weather. it will cycle too often. unit better used in summer-------good luck
Dec 16, 2007 | Kenmore 5365 Dehumidifier
Dehumidifiers Logo
346 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
