Question about Minolta BIZHUB 161F Black and White Copier
When i use doc feeder for copying or faxing it is black/& or blank
  • 106 Answers
Maybe he have problem the scanner motor,scanner board
Posted on Jun 08, 2011
WONT MAKE A COPY IN TOPFEEDER
Check the connection of the doc feeder to the copier. if you open a cover on the doc feeder does reflect on the copier? Ensure the doc feeder is aligned there is a small magnet right front side of the doc feeder that sits on top of a switch (Can not be seen underneath front plastic the copier when down. Adjustment bolts for the doc feeder is the rear right hinge only.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 21, 2014 | Konica Minolta Bizhub C253 With Document...
Big black line on paper
clean the scanner, lift the auto doc feeder and underneath is a scanner, look to see if there is white out or some other obstruction and clean with a rag soaked with alcohol
May 21, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
Feeds document too far before it starts copying.
The doc feeder is a little finiky, try letting go of the doc as soon as the feeder detects a doc in place and not force it through the feed slot.
Jan 05, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Copies have black lines on them after i replaced the toner
does the lines come when doing copies in the doc feeder only? or on the glass also?
if only in the doc feeder lift up doc feeder and clean the small strip of glass
Oct 30, 2008 | Sharp AL 1631 Copier
Problem with sending faxes
change a paper size in the fax setup
Feb 04, 2008 | Office Equipment & Supplies
Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Sep 30, 2007 | Brother IntelliFAX 4100 Laser Fax
Minolta BIZHUB 161F Black and White Copier Logo
35 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
