Question about Philips Magnavox 27MS343S 27" TV
How do i unlock a philips 24pw6006?05 wiyhout a remote control
5 Suggested Answers
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Posted on Jul 17, 2008
SOURCE: how can i unlock philips hotel tv 21ht3302/41?
If you're looking to "unblock" the inputs, (for example; connecting a dvd or a xbox, ps, etc) it is possible to do it if the tv is a philips...just follow this instructions to access the menu:
Use the Digit 0 -9 buttons to press digits
319753 followed immediately by the mute
button. Note: Digit buttons 3,1,9,7,5,3
and the mute button must be pressed
successively within 20 seconds for the
TV setup menu to be activated.
Then you just need to create another channel, add the input (vga, svideo, avg, hdmi, etc...) and store the channel
Posted on Nov 07, 2008
  • 30 Answers
SOURCE: i have a total control universal remote and need
should be 1 of these codes :
0060 0579 0035 0036
0346 0577 0214 0066
0110 0216 0366 0397
hope this helps :)
Posted on Oct 15, 2009
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Posted on Apr 17, 2010
Unlock my dvd player
try this
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
I bought mine tonight. The above procedure works perfectly. It is now set to 0, and I confirmed via firmware version page.
Cheers!
Sep 06, 2008 | Philips Magnavox DVD/VCR Dual Player
Crack code
here u go rate me Fix ya
1/press setup
2/go to the prefernces page.
3/type 9 6 5 3
4/select region
solved 100% by Fix_You
Aug 18, 2008 | Philips DCP855/37 Portable DVD Player
I lost my remote and I want to unlock my tv Philip plasma tv 32 inches
Do you have a smart phone? There is an android app that works really well in place of a standard remote.
Dec 08, 2014 | Philips Televison & Video
How do change pic. size wiyhout remote
There are several free universal TV remote control apps available for iPhone and Android. You can download and install one of these apps and select your TV model from the app's database to have full remote control again.
Aug 27, 2014 | Toshiba 40SL412U LCD TV
Locked exit
You can't do it with a remote control. You should have its original remote control to unlock it. No universal remote control will go. Contact the authorized service center for Philips to get a genuine remote control.
Nov 28, 2013 | Philips 28PW6006 28" TV
How to unlock the child lock without remote oc philips portable tv
No, I 'm afraid not my friend. Maybe you have a friend or someone you know who has a Philips or Magnavox remote control so you can unlock your set.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Jun 28, 2011 | Televison & Video
Philips DVD player dvp 3580 regional unlocking code needed to play region 1 dvd.
1. Press the Setup button on your remote control
2. Using your remote control, highlight but do not
select the Preferences menu
3. Press the 1 button on your remote control
4. Press the 3 button on your remote control
5. Press the 8 button on your remote control
6. Press the 9 button on your remote control
7. Press the 3 button on your remote control
8. Press the 1 button on your remote control
9. Using the Up and Down buttons on your remote
control select 1 for region 1, 2 for region 2, and so on, or
0 for multi-region playback
10. Press the OK button on your remote control
11. Press the Setup button on your remote control
May 05, 2010 | Philips Televison & Video
Unlock HTS 3555
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
May 05, 2008 | Philips HTS-3555 System
Philips DVP3960 uncolck code
region-free hack?
I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
Open the tray
Good luck
Feb 15, 2008 | Philips DVP3960
Philips Magnavox 27MS343S 27" TV Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
