Question about Sharp Notevision XG-C50X Multimedia Projector
There is a large green spot on the screen. Really noticeable when on a dark screen.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Either the Green LCD Panel is shot, and/or the Green Polarizer Glass. unfortunately the only way to fix it is to replaced the whole Prism assembly.
Posted on May 26, 2011
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
RU -44, small "pink" spot on screen.
Green is missing from the area where you see the pink (actually magenta) spot. This might be due to a large amount of dirt on the green lens. It may be due to damage to the face of the green picture tube. You need to remove the front screen so you can look into the lens and determine that.
Depending on the make and model of TV, the screen may be held on by snap fasteners and come loose when you pull on the plastic bezel surrounding it. Or the bezel may pull off to reveal brackets screwed into the cabinet that secure the screen. Or there may be a trim strip under the screen that pulls off to reveal screws. Remove those and the screen will swing up and off.
Once you can see the lenses, clean them with a soft rag and glass cleaner. With the set on, look down into the lens and you can see the face of the picture tube. If you see a dark spot on the face, the tube is damaged and would need to be replaced
Apr 22, 2009 | LG RU-44SZ61 44" Rear Projection...
Blue spots on the screen.
Assuming that an alignment tool is not your problem, if the blue spots are regularly arranged in rows and
columns, I would have to say that the blue filter of your three tube (red blue green) array needs service.
Apr 14, 2009 | Televison & Video
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
Green tint to bright spots on screen
Try to observe the problem when there is a white screen or predominantly white screen. If the screen is green or yellow where it should be white, its most likely a problem with one or more of the small LCD panels in the TV's light engine.
Its an expensive problem to fix. The light engine most likely will have to be replaced. Check with Panasonic customer relations for possible assistance.
michtech
Jan 30, 2009 | Panasonic PT-44LCX65 Television
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
Red spot when screen is black
Your light engine will need to be replaced as you have a LCD panel failure. Here is the link to the part number for the model 50V500 if you have the 50V500A it has a different part number. http://www.partstore.com/ProductDetail.aspx?ProductSKU=8286849&ProductType=PART&ModelID=374014
Mar 14, 2007 | Hitachi 50VX500 Television
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Sharp Notevision XG-C50X Multimedia Projector Logo
575 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
