Typically messages will be stuck in the outbox because they are unable to send. Usually because of large file attachments or server availability. If you are using outlook, try taking outlook offline then delete the messages. The option should be under the file menu and say something like 'work offline'. Once you delete the messages, don't forget to put yourself back online!
Hello thanks for using
fixya In outbox those messages are present which are in process of sending or failed to send If u want to delete messages from you outbox Go
to the menu>>Click the message>>Go to outbox messages,you will see
your messages>> Go to options options there>>they will be second option as delete message>> Press Ok. Message will be delete I hope
this solution will helpful 4 u. Best of luck Please
keep thumbs up in do rating THANKS & Keep
using fixya
delete the old failed messages out of the outbox.. delete ALL messages from the OUTBOX.. if they have failed previously or are too big they might sit there, then every time you go to send a new one or hit send/recieve to get new ones, it will try to send them again.
call the customer care and get the message center number..re enter the message sender number given by them in the message settings....switch off n ON ur mobile..ur problem will be fixed...if the problem persists give a complain to ur service provider...it ll be a problem due to many messages at a particular tym!!
wen i text any msg it doesn go it says messga send failed and resend from outbox and when i go to outbox and send it from there it says the same thing i need helpp pleasee anyone?
I had this same problem. Deleting and clicking "yes" at the warning screen would not remove the message from my outbox and the message kept resending for days.
Solution: In the Outbox, click "Menu" > Empty Deleted Items. Click "yes" at the warning. The message should now be gone from your outbox and your text buddy should now be able to regain sanity.
T-mobile credited back the resent text messages when I called them.
