Question about Garden
I have the Briggs & Stratton 5250 Generator Model 030204. It will not start. I think there is a fuel hose missing. Right next to carburator I have gas pouring out of hole. And the small round device that contains the float has a gold piece at the bottom that looks like a hose should run from it to where the fuel is pouring out of. Is this the problem with why it wont start? If so, what size fuel hose do I need. Or is something else wrong
SOURCE: Briggs & Stratton Burnt Brushes
I did find out that the inner slip ring was worn down. Still unknown why and the repair tech we took it to twice just replaced the brushes and never looked at the slip rings.
My solution, which has worked for over two months now (knock on wood) is as follows:
The slip ring on this unit can only be replaced by replacing the whole rotor assembly. I looked at the width of the brushes and the width of slip rings. The slip rings are twice as big as a brush. The solution was to move the brushes outward by one brush length. In order to do that, I had to turn the brush assembly around because of the extra plastic on the unit and space it out one brush length. Note: Still hook the wires as if the brush assembly was not turned around.
I used an old brush assembly and cut the two areas where the screws go through to make my spacers and it works perfectly.
Posted on Dec 03, 2008
  • 16 Answers
SOURCE: fuel line replacement
I recommend remove all fuel from the tank. Remove the hose from tank to carb. take the tube with you, when getting new hose.
Posted on Jan 19, 2009
lilmikew99
  • 122 Answers
SOURCE: 6.75 briggs and stratton carb problem
might have picked up some sedements from being low on gas. check your diaphrams in the card a small hole or even dirt can stop it up
Posted on May 10, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a craftsman lawn tractor with a
If this tractor/engine has a fuel solenoid at the bottom of the carburetor, with a small plastic plug in on the side of it, you will have to unscrew the solenoid to remove the bowl. It takes a very thin 1/2" wrench to reach the flat sides on the solenoid and not mess anything up. I use an old tappet wrench but I don't know if they even make those anymore. If you have to, get an old cheepie wrench and grind it down equally on both sides where it will fit. If it doesn't have the solenoid you should be able to just remove the bowl nut and gently tap the lower edge of the bowl to break it loose.
If the thing is badly varnished up, you should remove it completely and rebuild it or replace it. There will most likely be varnish in the main jet as well as just the bowl and sometimes replacing is the better alternative.
If you want to post the Sears Model number, I will look it up and tell you the difference in price of kit vs new.
Posted on Sep 20, 2009
Model o3o319 portable generator not getting gas or air has spark
your filter inside tank may be clogged take aome air and blow in the out let of gas to see if it maybe dirty. check the fuel line itself maybe weak inside and collaisping and not allowing fuel.
May 10, 2014 | Briggs & Stratton Briggs and Stratton...
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Turn on fuel cock, motor starts, after a few minutes gas starts flowing out of the carb at the air filter
The needle valve on the carbureator float is stuck open or has a little debris stuck in it. You will have to take the bowl off and clean out the seat for the needel valve. A Qtip or small wooden dowel works best.
Dec 07, 2013 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Motor was loping i cleaned plug and filter now it runs like 3 min n quits
carburator needs to be cleaned,and put new fuel in the tank as well as a gas stable product
Jun 07, 2011 | Briggs Stratton Portable Generator 305cc...
Wheres the fuel switch on a 2003 model seat ibiza
hi
follow the fuel line from the gas tank to the carburator
regards savumihai71
Dec 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
It started but when i pluged in ti it it quit. has not started since. checked plug and it was loaded with gas. install new plug and tried. check spark and it appears eratic. pulled air filter off and it is...
sounds like the float is stuck, how long has it ben setting around? try some carburetor cleaner. spray the carburetor down. empty the fuel tank put fresh fuel with fuel treatment. you may have to remove the spark plug, pull starter string a couple of times to clear out cylinder make sure spark plug is dry put back in and try to start the generator.
Dec 10, 2009 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
