We have a TCL split air con unit. The model number is: TAC 12CHSA/BU. Can you help please?
flatech
  • 111 Answers
SOURCE: TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
Posted on Nov 14, 2009
SOURCE: TCL air conditioner wiring
John what is the problem ? My 18CHS gave me problems but are now fixed. Maybe I can help
Posted on Feb 24, 2010
  • 1183 Answers
SOURCE: i need a instuction manual for my amcor portable
http://dl.owneriq.net/8/81da8c5e-7d0e-4373-a7d9-a4de1b988401.pdf
try this web site. I has the manual you are looking for.
Hope this helps ya
Posted on Mar 16, 2010
Testimonial: "thank you, very helpful, printed and stored."
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
hvac1960
  • 2133 Answers
SOURCE: My TCL TAC-12CPA air con
PF-Power failure in pcb board. Check power to indoor unit and then to PCB. If no power, repair your PCB>
Posted on Jan 03, 2011
I have ac tcl model tac-42cf is not working and have error code in the display,how i can fix this trouble for this error?
I have the same problem..but i fixed that. if u have the same type with mine; TCL split type ac, TAC-42CF/A,380V 3N~. Then u can try this.
1. open indoor panel.
2. find 2 cable in socket pcb that is p11 And P12, u plug p12 on p11,and p11 on p12.
3. if not solved, try the same just like point 2 on power suply 3phase cable R.S.T try S to R, or else.
4. hopefully ur problem solved.
Aug 14, 2012 | Cars & Trucks
My TCL TAC-12CPA air con display panel show "PF" and it would not be able to start.
Jan 02, 2011 | Heating & Cooling
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
Feb 06, 2010 | Heating & Cooling
Dec 18, 2009 | Heating & Cooling
Through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Sep 10, 2007 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
