Question about Garden
How to convert from vacuum to blower craftsman 2 speed power blower vacuum model 257.796351
3 Suggested Answers
SOURCE: craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Posted on Apr 24, 2009
rotorcrafts
  • 302 Answers
SOURCE: Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
Posted on May 19, 2010
I'm looking forward to this part of my Craftsman 225 mph blower / vac
Most of the parts that use to be available for that model are no longer available, it is cheaper to buy new one.
Models parts no longer available
136.740360
136.748270
http://www.sears.com/craftsman-2-speed-blower-vac/p-07130376000P?sellerId=SEARS&prdNo=2&blockNo=2&blockType=G2
Nov 01, 2016 | Craftsman Garden
I need a 2 speed switch for craftsman Vac/leaf blower as well as the short cord
Go to sears parts direct for all craftsman parts.. you will need your model info... it will be for example 536.00078 just like that...decimal after the 3Rd digit.. likely on a sticker..
Nov 08, 2015 | Craftsman Garden
Need repair manual craftsman yard vacuum model 247.77013.0
Go to searspartsdirect.com and enter the model number and it will give you an options for the manual. Hope this helps.
Aug 01, 2014 | Craftsman Yard Vacuum System 4 in 1 190CC...
How to start gas powered snow blower
A model number and serial from the engine would help. Also the manufacturer if its Briggs or tecumseh
Nov 09, 2013 | Garden
How do I convert from blower to vac
First, remove the blower tube. Then connect the collection bag on the blower tube outelt. Then open the bottom fan cover. Keep it open and connect the vacuum tube into the opening.
Dec 05, 2010 | Craftsman 225 Mph Electric Blower Vac
How do we activate blowing system on the blower/vacuum? I don't know how to switch from vacuum to blower?
1) the pick-up tube for vacuum is removed
2) the vac bag is removed and blower nozzle is installed in it's place
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
Same model...same problem!
its the carb , have you tried setting the low speed
Aug 30, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
I need a replacement bag for my craftsman vacuum.
www.searspartsdirect.com probably has it.
Aug 08, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower/vacuum
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
