Question about Yard Man YardMan 11A41K3001 21Inch 173cc Kohler OHV Gas Powered BagMulchSide Discharge Lawn Mower (NonCARB Compliant) ()
Mower runs with choke on turn choke of rev up and down ?
    Scholar:
  • 87 Answers
You have a dirty carb, start off by cleaning and draining your carb and your fuel tank, remove the fuel bowl on your carb and use a spray can of carb cleaner to clean the tank and carb bowl. be careful not to ruin or loose the orings that seal the carb bowl,,put it back together with fresh gas and you should be ready to go for the summer. always be sure to add fuel stabilizer to you fuel to keep your gas from going bad and gumming up your carb,.. You can get the stabilzer at any parts store even wal mart has it it the automotive section of the store..
Posted on May 26, 2011
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Why does my poulan 2075 runs with choke on but not when i push the choke in?
Crank seals could be leaking air in,or carb settings incorrect.screw both mixture screws right in,then out 1.5 turns..set low mixture screw for highest idle,you may need to unscrew the idle screw a bit to keep revs down.adjust H mixture screw at full revs,to get max revs,then unscrew 1/4 turn.may need to reset idle
Jul 23, 2014 | Poulan Garden
Countax C300H running problems
carb jets probably need to be cleaned
May 14, 2014 | Garden
My br420c blower runs fine for about 20 seconds and then shuts off like the switch has been turned off
possibility 1) It sounds like it is sucking air with the gasoline. 2) don't rush the choke, leave it running on high with 1/2 choke. When you go to move the choke to off, move it very very slowly while the governor can catch up and raise the revs. Or slow the revs down before turning the choke off.
Oct 23, 2013 | Stihl Br420c Magnum
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
My lawn mower is surging and spark plug is black is this lack of air briggs& stratton . plus runs ok when running out of petrol /????
Are you running it with the choke on? Also if the air filter is dirty it will do that as well. Black plugs means it's getting too much gas and is not getting the proper air to burn properly. Some engines if you rev them up with the handle right as fast as it will go automatically the choke is on.
Sep 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Stalling after one hour run time
Sounds to me like you need to replace the ignition coil,they will go open when they get hot and when this happens the plugs will stop fireing.
Apr 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
ONly will run with choke on as soon as i turn choke
at the bottom of your carb there is a bowl with a screw in it, try turning all the way to right till tight then back off about one and a half turns, also make sure your air breather is not clogged and it is choking for air or getting too much as its running try adjusting the air breather nuts and see if this makes a diffference it might not be the choke it might be staving for air or getting too much if not tightened down.
Apr 11, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Motor does not change for long grass , it cuts out, instead of automatically increasibg the RPM - Talon Motor Mower
i have a talon lawnmover starts get but revs are low ,i move choke up and down doesnt change revs anymore
Nov 29, 2009 | Talon Electronics - Others
Yard Man YardMan 11A41K3001 21Inch 173cc Kohler OHV Gas Powered BagMulchSide Discharge Lawn Mower (NonCARB Compliant) () Logo
275 people viewed this question
Top Yard Man Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Thomas Perkins
Thomas Perkins
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
