Question about Dryers
I have a brada dryer and it will run for about two minutes and then shut off and flash an error symbol on the front that looks like t0 do you know how i can fix it without having to pay some repair man to come out?
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
ngfam1
  • 639 Answers
SOURCE: error code E9E
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This is an electronic problem and must be replaced by factory service!
If it happened from th beginning call factory service right away, it's under warranty, you do not pay for it!!!!!!!!
There is no other choice!
If the dryer was 10 years old I would recommend to trow it out and not spend a dime on it! Are you ready to buy a new machine??
If not let service fix it and get back to having clean clothes!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
localwonder
  • 6784 Answers
SOURCE: Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Posted on Jun 09, 2009
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
Where can I order Parts For A Brada Dryer
Hi Armand,here's a link to some control knobs,if these are not them,let me know and I will search more.You can give me your dryer's model number. Samsung Dryer Knob Dial Button Parts
Feb 08, 2016 | Dryers
I have a brada dryer that runs for two minutes then shuts off. It shows a code . I tried my braker switch didn't help. Cleaned it all out and still the same.
Brada Appliances Product Support ' ManualsOnline.com
www.manualsonline.com/support/brada/
Manuals and free owners instruction pdf guides. Find the user manual and the help you need for the products you own at ManualsOnline.
Sep 30, 2015 | Dryers
I get a t0 error code and the dryer stops after a minute or less. This code is for clogged vent but I've completely cleaned out the vent and washed and dried the screen.
There is a vent pipe that runs from the lint trap to the back of the dryer. There is also a sensor on that pipe that supposed to shut the dryer down if there isn't proper air flow. You might want to take the back off and clean out that pipe. Also when I disassembled mine I found an incredible amount of lint inside the case. I try to get in there and vacuum it out once a year now.
Jun 06, 2015 | Dryers
Shutting down power on my fridgidaire 2008 dryer that stops and lights start flashing
without make/model we have a real hard time looking for a solution
Mar 22, 2015 | Dryers
WHY IS DRYER TURNING OFF AND 4 LIGHTS ON PANEL FLASH
Good Morning Friend,
I understand your Frigidaire dryer, model# FEQ1442ES, runs for about 10 minutes then turns off. I also see, that when it turns off, all the lights on the front panel are flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
May 05, 2008 | Kenmore 85871 Electric Dryer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
496 people viewed this question
Top Dryers Experts
