My pc will not switch to pc it comes up with the message not support mode and I cannot get back to desktop I have tried switching off and unplugging but I cannot get anywhere
How do I get out of no input signal
Hello
The video signal is not getting into your display.
Check the connections on both sides of your cable (display side and display card side). If that didn't help, switch off your PC, make sure youre display card is in its correct place (try taking it out and putting it back again). Switch on your PC and check again. If the problem continues, try replacing your display card.
Aug 11, 2014 | Sony VAIO Computers & Internet
My 8 year olddell desktop wont come out of standby mode. Even when switched off then turned on again the light flashes like in standby mode. Tried changing cr2032 battery on motherboard as advised by...
Hi elaineblackb ,
Try to do a power cycle and see if that will work.
  1. Turn off your computer and unplug it from the power outlet
  2. While unplug, press and hold the power button for 15 secs.
  3. Try to turn it back on.
Keith
Jun 13, 2011 | Computers & Internet
I have an E4210 desktop malfunction
listen carefully dude... unplug all the cabels..... open the cabinet remove the ram ...clean the board....there is a panel where u can eject the fan . do it. and again place it.. check all slots (optional). assemble back ur pc..if u forget then draw the cables and the ports u unplugged from..
Apr 15, 2010 | E-Machines eMachines Desktop PC
I start my computer but it wont btake me to my windowa it takes me to restart window normal or on safe mode what do i do
hi click restart on normal mode then wait for it to load up properly then shut it down, wait for it to shut down, then switch it back on if it then comes up with this message you either have a problem with windows software or maybe problem with hardware on your computer
Jan 20, 2010 | E-Machines eMachines Desktop PC
When I tried to boot up only goes to the gateway logo, and nothing else, I tried in safe mode no response, please help
Try to open the case and remove the battery. Make sure the pc is unplugged first. Switch on the pc and then right back off again and replace the battery. This usually resets the BIOS and will return the pc to its basic state. The battery is round and small like a coin. I hope this works :).
Aug 17, 2009 | Gateway 420GR PC Desktop
CASIO TE2200 Error E010 while drawer is closed
This type of problem is normally caused by a switch. When the drawer opens, the switch closes and the machine goes into 'drawer open' mode to prevent another transaction. The switch or the switch activator has probably failed.
Remove the entire drawer assembly, meaning everything that comes out when the drawer is opened. Use a flashlight and look at the inside rear of the drawer opening to see if you can see the switch. It may be a lever or a button and it may be in line withe the drawer or in may be off to one side. When it is located, try to press on the button or lever. If you can and the machine goes back to 'normal mode' the problem will be identified and you will know that the switch is good. Now you need to locate what actuates the switch to see why it is not making contact. Look on the part of the drawer that should come in contact with the switch. If a small, thin piece of plastic has broken off, tape a small piece of a hard substance in that area. Close the drawer to see if the 'open' message goes away. If id does not, try a thicker piece. Repeat until the 'open' message goes away. When that happens, glue the last piece in place.
If the 'open' message does not go away when the button or lever is press, it indicates that the switch is bad and needs to be replaced. Most of these switches make contact when the button or lever are not pressed. In the short term you could locate the switch and disconnect one wire. That would simulate the button being pressed. You would just need to remember to not start another transaction until the drawer is closed.
Good luck, and please let me know how it works out.
Feb 22, 2009 | Casio Parts Cash Register PC Desktop
Aspire AM1201 does not boot up.
hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Feb 16, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Won't power on
see what power button did you hit? usually cpu has 2 power buttons one on the rear and other on front, maybe you have hit the power button at the back, try inspecting it with a flash light if it's a toggle switch just switch it back to permanent on and use the power button on the front instead.
Oct 20, 2008 | ZT Group NC001 (CANC001) PC Desktop
General protection error message
try go to Safe Mode..Turn On your PC,upon booting,press F8 steadily then choose Safe Mode then press enter.. If still doesn't work,let me know here..
Jan 13, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
