Question about Nintendo 3ds Handheld Game Console- Cosmo Black for DS
Won't connect to Wirelss hot spots outside of home. Wi fi at home works but anywhere else I just get a Error code 003-3201 pops up.
  • 75 Answers
Is the Wifi strong enough to go outside with it? Do you change the WiFi spot outside of your home? For example, if you are at a gas station, do you connect with your home network? This doesn't work.
Posted on May 26, 2011
Unable to get internet
You can separate the troubleshooting into parts. Go to a place having a wi-fi internet hot-spot, like Starbucks or Gloria Jeans'. Assuming you are in the USA:
http://www.wififreespot.com/
Get a coffee and turn your tablet wi-fi on. From
http://www.manualslib.com/manual/742236/Rca-Rct6272w23.html?page=11#manual
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it. Tap 'Agree to conditions' if necessary.
You should then be able to go to a webpage. Once you get this bit working, you can turn to your home internet.
You need of course an account with an ISP, who will probably supply you with a gateway (modem/router). If you only have a modem (connection box to the ISP) that does not have a wi-fi capability, you will need to get a router (wi-fi broadcaster). These can be quite small and neat.
http://phandroid.s3.amazonaws.com/wp-content/uploads/2015/10/OnHub-by-ASUS-Screen-Shot-2015-10-27-at-5.29.02-PM.png
For assistance on this contact your ISP tech help line, since some of the advice is peculiar to the equipment they use.
Connect the router (if you needed to get one) to the modem with an ethernet cable
http://cdn2.pcadvisor.co.uk/cmsdata/features/3502678/ethernet-cable.jpg
and follow the setup instructions that came with it. Then do the same as in the cafe wi-fi hot spot. It should work.
Mar 03, 2016 | RCA 8" Android Tablet w/Dual Tuner
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
Why can't I connect to wifi anywhere?
there are two systems.
Mobile data and private Wi Fi networks.
Some Wi Fi networks with limited range are available at Wi Fi hot spots but you need to know the password to connect.
In my country Australia Telstra is going to offer Wi FI hot spots for its home users broadband customers and will then bill the usage to their home account. https://www.telstra.com.au/broadband/telstra-air
this is a new network concept in its infancy
Dec 31, 2015 | Tablets & eReaders
BD-J Error Code: 0108 has come up on my player how do I up grade? I have tried dowoading from a disc and memory stick but the blu ray player won't allow any what can I do?
If your blue ray player has Wi-Fi built-in and you have a wireless (Wi-Fi) home network, the way to do the upgrade is via the Internet by connecting the player to your Wi-Fi home network.
Dec 26, 2014 | LG Televison & Video
Authentication. problem
Is this your home network or are you trying to connect at a hot spot? Can you see that wi-fi is available? It may be as simple as needing a password to connect. I need more info.
May 28, 2014 | Computers & Internet
Wi-fi won't connect, how do I fix it
have you had a fire or burglar alarm fitted recently? the signal emitted (even when off) can scramble the wi-fi.
Aug 06, 2012 | Apple iPhone 4S
Bought dongle for my ocean netbbok but dont know how to connect
Usually you install the software for the for the dongle, then plug it in.
If it's working it should find any available wi-fi signal thats close enough.
You will probably see a notification on the task bar in the bottom right corner of the screen. If you click it you should get a list of the networks, including yours. Select yours click connect and it should try and connect and ask you for the security key which you entered when you set up your routers wirelss security options.
If you mean a dongle that lets you get wi-fi anywhere through a phone service network then the instructions should be with it, if not ask you dealer/supplier.
Feb 05, 2012 | Computers & Internet
How can i browse the internet using wi-fi
Do it like this :
* go to wi-fi settings
* search for wi-fi and engage or connect (check if there's an encryption cause a password is required)
if you go to a free hot spot location,this will works.
* after the phone connects to a network,you can now start browsing using the internet icon on the menu.
hope this is helpful enough for you.thank you for visiting fixya.
Jun 14, 2011 | LG GW300 Cell Phone
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
I GO TO NINTENDO WIFI.COM AND I DON'T KNOW WHAT TO CLICK ON TO GET MY DS LITE'S WIRELESS CONNECTION CODE FOR WIFI PLAY ON POKE'MON PEARL VERSION!!!!
Usually when you connect to Wifi, you automatically get a connection code. You do not usually need a code to connect... Something may be wrong with your DS's connection.
Dec 21, 2008 | Nintendo DS Console
Nintendo 3ds Handheld Game Console- Cosmo Black for DS Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
