Question about Samsung TV Remote Control
The TV: Samsung model LE32 R41 BD, code LE32 R41 BDX/XEU, type no RE32EO, Remote: BN59-00463 one function works: the volume button, also when you click a button on the remote, the TV receives the signal, light shows, but you cannot change anything, no other button works. Could something lock the remote into one position?
2 Suggested Answers
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
I have been given a Samsung BD-P1600 (xeu) blu ray player.\r\nThe issue it has is no response from the remote(it IS working OK) and the word 'LOAD' on the front and on/off,open /close functions...
try to use a toothpick and put it on the small hole just beside the player so that you could remove/insert discs. Play it manually if the remote did not work...
Sep 17, 2011 | Samsung BD-P1600 Blu-ray Disc Player
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Sep 16, 2010 | Samsung TV Remote Control
I have a Insignia tv and I need the remote code for the bd-1600 remote. I want to use the bd-1600 remote to control my tv.
Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
Jan 02, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Sep 12, 2009 | Onkyo TX-SR606 Receiver
LCD LG TV 37LG50 / Samsung bd-p1500 blue ray player
644 works with the Samsung BD-P1590/BD-P1590C/BD-P1600 om my Blue Button Dish Remote for the 722k.
Dec 28, 2008 | Televison & Video
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Bd-p1200 remote control problem
http://www.remotecentral.com/cgi-bin/mboard/rc-discrete/thread.cgi?4481
go there and reconfigure the remote with the details on this page should pretty much fix it!
Dec 17, 2007 | Samsung BD-P1200 Blu-Ray Disc Player
Samsung TV Remote Control Logo
119 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
