Question about Fossil Abacus AU4002 wristwatch
I lost the Wrist Net power supply but I do have the charger base. What voltage is the power supply?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 172 Answers
Wow, I haven't used my SPOT watch in years--but I found it!
The charging base for my Abacus AU4000 uses an adapter rated at 12 volts, .11 amps, center positive. I believe that all the charging cradles for the Abacus Wrist Net series watches were the same--the different model numbers referred to different case and band options.
Good luck, and don't hesitate to follow up if you have any additional questions.
Posted on May 27, 2011
How can I obtain a the bracelet pin that holds the bracelet to the watch base? I currently have the pin but have had the set screw that holds the pin to the watch base come and is lost.
Well if its a spring-bar you're looking for you can generally find assorted sets fairly cheap on ebay....if you need a screw pin you could try ebay or possibly a radio-shack? I think I've found smaller screws there before generally used in small electronics.
May 06, 2013 | Kenneth Cole KC3485 Wrist Watch
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
I purchased a abacus wrist net on line with msn direct , and my battery isn't charging with my charger.
Your issue may not be that the watch is not recharging, it may just need to be reset. This will work on most, but not all of the abacus watches. You need to press all but the top left button at the same time. Do this 20x if successful, your watch will magically power up. I have this issue from time to time, usually right after a static shock. Hope this helps!
Dec 15, 2009 | Fossil Abacus AU4002 wristwatch
Need new battery. How do I do that?
Around the outer edge of the watch there will be an indention. Pry open with a small screwdriver. Your internal compartment should be right there.
May 05, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Corrosion
sounds like the acid level in your sweat is high a lot of watches onlly have a light plated skin over base metal. if you look at whats scraping you you will see the edge of the surface metal and the base metal . if this helps please rate.joe
Nov 19, 2008 | Citizen Eco-Drive BL006056H Wrist Watch
Baby-G 3687
This is suppose to be an auto setting watch, see Support FAQ link...
http://www.baby-g.com/support/
Find the manual here...
http://world.casio.com/wat/download/en/manual/
Jun 25, 2008 | Casio Baby-G BG370S-4V Wrist Watch
DOSWNT WORK
Take it to a good jeweler. He will evalauate it for you. Most mechanical watches are very valuable, and expensive to buy!
Jerry G.
May 13, 2008 | Watches
Broken strap.
contact Cartier. www.cartier.com Donald
May 20, 2007 | Cartier Santos W20056D6 Wrist Watch
Fossil Abacus AU4002 wristwatch Logo
343 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
