My DC jack broke what should i do. - Computers & Internet
  • 340 Answers
I am assuming you mean the DC jack on the motherboard in your laptop?
You can repair it yourself, or take it to a repair shop and pay to have someone do it.
To repair it yourself, you'll need:
1) A new DC jack (though sometimes you can fix the broken one)
2) The disassembly guide to your specific model of laptop. Google the phrase "laptop make/model disassembly" and one should come up pretty quickly. Guides are generally step-by-step with pictures included, and putting it back together is just the reverse of disassembly.
3) A soldering iron and solder. 15-30 watts for delicated boards like a motherboard. Once you've pulled your motherboard out, You can de-solder the broken DC jack from the motherboard (if necessary) and solder the new one on. DC jacks are generally 2-4 solder points and fairly simple to press back on.
Posted on May 26, 2011
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
Tip
Laptop wont boot power on
ive had many jobs where people thought the dc jack is bad
you can test this with a toothpick by trying to move the pin in the dc jack
if it moves a little bit , chances are pin is broke,
the ac adapter many times shows green light , but still may be defective
due to the cheap ends to plug into laptop, all made of plastic today
on Jul 21, 2009 | Dell Latitude C600 Notebook
DC centerpin broke. How do I fix it?
The DC jack must be replaced, in order to do that, the unit must be taken apart down to the motherboard level, a job for a professional.
Mar 19, 2012 | ASUS Computers & Internet
I have an acer aspire one 8.9" running windows xp.
There are two wires of importance - the red and the black, positive and negative respectively. Pay attention to how the adapter plug outputs power to the jack - they should have a label that indicates whether the the inner or outer connections are positive or negative. Make sure the jack is wired accordingly to the adapters's plug - positive goes to positive and negative goes to negative. Use a voltmeter to verify the voltage and polarity of the plug.
Nov 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
Pin inside ac charger broke off inside my dc power jack
i highly recommend u find a way to remove the pin as u would struggle to find a dc power jack for the hp mini 2140 motherboard ,if u manage to get the pin out ac power chargers are quite resonable on some internet auction sites
Mar 11, 2010 | HP Mini 2140 Notebook
Problems
first is the ac adapter hard to tell if its working or not
even if green light is on, it could be the end that plugs into laptop
next is the dc jack , take a toothpick or something
and touch the pin inside the jack where you plug the adapter
if this moves just a bit, the pin is broke , a new dc jack is 5 bucks on ebay or more, but youll have to take apart to install new jack
Mar 01, 2009 | Toshiba Satellite A60 Notebook
How can i open up my Gateway 7322GZ to replace DC power jack?
Here is the direct link for downloading the manual that will walk you through the procedure you wanna pursue.. It's gateway's original manual n hope you get some idea about how to open up ur laptop
http://www.adrive.com/home/downloadfile/136709577
Feb 13, 2009 | Gateway 7322GZ Notebook
DC input jack broken
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
Toshiba dc connector
If the laptop still works, then there would be no need to replace the motherboard. The DC jack is replaceable/repairable. What would be more challenging is the disassembly and eventual exposing of the bottom part of the circuitry where the DC jack is soldered into. Often the DC jack would have at least 2 solder point (not more than 3). This might interest you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 25, 2008 | Toshiba Satellite (K000004080) Motherboard
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
