Question about Asko D5122XXLS 24 in Builtin Dishwasher
Asko dishwasher D5122XXL I've got the F2 light flashing. How do I reset it? Or do I have to get service people to do it? I think there's nothing wrong with the pump or drain, since I actually poured a jug of hot water in to the dishwasher. ( it's hooked up to cold water pipe)
2 Suggested Answers
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
How do I open the drain pan
You should be able to just pop it up. Try a flat-head screwdriver if you need to. If that doesn't work, I would suggest calling a plumber. A plumber may be able to get the drain pan open.
Elisa Jed ' http://www.rjlplumbing.com.au
Mar 03, 2014 | Asko D5122XXL 24 in Builtin Dishwasher
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Asko d1876
I'm not sure about that model, but on an older one, just under the drain area there is a piece os styrofoam attached to a switch. I guess if it rises it activates the circuit. Problem is if it drys it sticks, so push it down with your hand gently. This involves taking off that bottom kickplate area, but that's the only way in there.
Jan 25, 2009 | Asko D1876 Dishwasher
ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Jan 19, 2009 | Asko D1776 Built-in Dishwasher
Asko D5122XXLS 24 in Builtin Dishwasher Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
