Question about Gateway DX4300-03 Desktop PC
On my dx4300 the monitor shuts down randomly and then the computer will not shut down. i am unable to power the computer down using the on/off button. i have to physically unplug it from th ewall inorder to start the computer
  • 50 Answers
Make sure the monitor driver is up to date.also make sure the monitor is fully plugged in.
Posted on May 26, 2011
Motherboard troubleshoot
Try removing the graphics card and any un-necessary PCI components, and plug monitor in using the provided onboard VGA slot.
Jun 08, 2012 | Gateway DX4300 Acer Foxconn Bengal RS780...
My gateway dx4300-03 starts up fine and then about 5 minutes into working the monitor goes blank and the computer seems to go into sleep mode and won't restart until I unplug from the back and re plug in. ...
By Cyclontech!
Hi, The solution to fix the problem is by changing your power supply. Just make sure that you replace it with a 500W or higher and not with the same 300W which does not have enough power for this system, plus it is defective. I have changed the power supply to 4 diferent gateway PCs same model dx4300. And all 4 are working perfect. And run a check disk on CMD to fix the disk errors that were created every time you unplugged it and turned it on again.
Oct 28, 2010 | Gateway DX4300-03 Desktop PC
My computer monitor keeps shutting off randomly for no reason. It isn't the sleep function I've already checked that and it happens when you are in the middle of using the system. I am running xp
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options.
Now you will see Power option Properties.
Now see the Settings for normal power scheme.
Under this Make sure that the options like Turn off monitor should be set on never and not on After 5 mins or 15 mins
After changing the settings hit on the apply button and then click on ok.
Check this link and you will be able to unuderstand more...!
http://www.microsoft.com/windowsxp/using/setup/tips/sleep.mspx
still you have problems let me know..!
May 10, 2010 | Computers & Internet
I am using Vista operating system. If i use my computer more than three hours, i can't turn off my computer. The monitor shows that unable to shut down. Then i have to take the battery from my to turn off...
You can hold the power button down for 5 seconds to cut the power in a safer way than removing the battery. Search microsoft techbase/support center to find solutions to why it won't shut down.
Apr 19, 2010 | Computers & Internet
My monitor turns off every 2 minutes, even when you re power the monitor it will just shut down randomly. anybody knows whats wrong with it? and how much it will cost for repairs?
does it always shut down every 2 minutes? or is it "random" like you said? i ask because it can be configured to turn off as desired (that is if it is not used).
http://www.tothepc.com/archives/configure-your-computer-to-turn-off-automatically/
i think this website might be able to help you
Dec 16, 2009 | AOpen F2715 (Black) LCD Monitor
Two month old Gateway DX4300-03 randomly shuts down when on the internet.
I have the same pc my power supply went bad after 2 weeks.Pack up the pc and return it ASAP I have nothing but problems with mine.Gateway use to make good pcs, those days are gone,mine was a gift and I had to keep it.
Nov 19, 2009 | Gateway DX4300-03 Desktop PC
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Monitor randomly shuts off and computer restarts
After you turned it on and the screen shut off, check the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If the computer shut down immediately after the monitor shut off, it might be because of fault operating system. Check with another monitor.
Thank you,
Mar 08, 2008 | HP Compaq FS7600 17" CRT Monitor
Gateway DX4300-03 Desktop PC  Logo
210 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
