Question about Dean Markley Artist Transducer Acoustic Pickup
I have the Dean Markley Artist Transducer Acoustic Pickup installed in my Yamaha classical guitar. Is there a recommended cable to use because EVERYTIME I take the guitar to the rehearsal studio and to gigs, I have to mic the guitar because the sound is ssooo minimal that the amp or PA system that it is hooked up to has to be turned up all the way and it is still not loud enough. The transducer is placed inside the body of the guitar on the bridge. Thanks for your help!
What type of guitar is it other than accoustic need more details
There are two main types of acoustic guitar namely steel-string acoustic guitars and classical guitars. Steel-string acoustic guitars produce a metallic sound that is a distinctive component of a wide range of popular genres.
May 10, 2015 | Music
Tip
How to Choose A Good Beginner Guitar
Many guitar beginners go for acoustic guitar as their 1st guitar. It not a bad idea to get started with acoustic guitar. Listed here are a few greatest acoustic guitar models you can take into account when you buy your 1st beginner guitar.
Being a Japanese electric corporation, Yamaha began to make all kinds of instruments include guitars and grew to be a brand-new star in the market . Their guitars targeted at all kinds of customers from learners to skilled musicians.An example of the quality affordable beginner acoustic guitars they supplied is Yamaha FG700S. This model has a solid spruce top and laminate sides and back with the good tone just cost you about 200 bucks. Most beginner's acoustic guitars usually have high action that is the gap between guitar strings and fretboard. The sound of this Yamaha guitar models is very excellent regardless of the high action of the factory setting.
Fender is a reputable electric guitar provider and provides consumer with its Fender type electric guitars. Fender acoustic guitar is not just as popular as its electric guitar. Yet the low end entry level line of Fender acoustic guitars are also the number 1 choice for some beginning learners. On most online shopping websites, you could find Fender acoustic guitar. One of the best entry level acoustic guitar model of Fender is the Starcaster acoustic guitar. It owns solid top and laminated back and sides, that is great for its price tag. In brief, Fender Starcaster is an inexpensive beginner guitar.
Alvarez is a guitar brand that is not as famous as other giant companies. The Regent series from Alvarez is affordable as well as built with premium quality. This model has solid top and Dreadnought size. The sound is deep and powerful. You might feel it is a more expensive model if you hear it the first time because the tone is quite distinctive and awesome. The price of Alvarez Regent is about TWO HUNDRED bucks which is very appealing and might be the greatest affordable solid top guitar model.
I will be really pleased if the information above could help you find the perfect entry level guitar model. To get more details on guitar models and brands for beginners, check out Beginner Guitar
on Feb 25, 2014 | Music
I have a Yamaha 12 string fg230 red label,575925 .what year was it made?
here is Yamaha 's Serial Number Wizard site. Yamaha Corporation of America
Also check out here..this is even better
Serial Number Chart For Acoustic and Classical Guitars
But in looking your number up I cant find a reasonable explanation. No letters...and there are 6 digit numerical numbers but they dont match yamaha's codes...I would call yamaha and talk to a tech at 1 (714) 522-9000 Good luck
Feb 26, 2015 | Yamaha Music
Issues With Dean Markley ProMag Plus Acoustic Pickup
Hope you didn't throw it out. I know this is a bit late.
Cleanly remove about an inch from the end of the cable.
Loosen screw in the jack (yeah, it's there on the side).
Put cable back in jack and push it till it won't go anymore.
Tighten screw. You need to tighten enough so screw will breach the insulation and make a ground connection.
Oct 12, 2012 | Dean Markley ProMag Plus Acoustic Pickup
I have a dean markley promag grand acoustic pick-up which connects to a plug in stap button. when i plug in there is no sound unless the volume is turned up on the amp to the max and then a very faint...
The output of this is fairly low. Do make sure you have steel strings rather than bronze for magnetic pickups like this. Make sure this pickup is oriented per the instructions.
Jul 02, 2011 | Dean Markley ProMag Grand Guitar Pickup
The low end gives a lot of feedback if turned too high. Any reasons why?
Probably the soundboard is resonating. If you out your hand on it or the strings it will probably stop resonating if it was just on the verge of feeding back. This is the main reason why solid body guitars were invented in the first place.
There are ways to minimise this, however. Speaker placement, eg have the speakers beside you and facing away to the audience. Stand further from the speakers. Use an eq pedal and lower the gain around the resoant frequency. Use a chorus/flanger pedal. This can help smear the frequencies and reduce feedback. If you google "reduce acoustic guitar feedback" you should find other ways. Also, if there is a way to increase the gain of the pickup by placement, do that.
Mar 05, 2011 | Bass Dean EXotica Quilt Ash Eqab Acoustic...
Wiring for a dean edge 4 string with one soap bar pickup
You might find it at http://www.mediawebsource.com/guitar/pickup.htm If you can figure out what brand the pickup is you could check the manufacturers site. http://www.guitarelectronics.com/category/wiringresources/ has original factory wiring diagrams for guitar and bass for various pickup manufacturers. Hope this helps.
Jul 10, 2009 | Dean Edge 4 Bass Guitar
Acoustic Guitar - Poor Sound Quality/Tone
might just be the pickups and their age. or a faulty cable
Apr 02, 2009 | Washburn Music
Dean Markley Artist Transducer Acoustic Pickup Logo
63 people viewed this question
Top Dean Markley Music Experts
Vito Vacirca Jr.
Are you a Dean Markley Music Expert? Answer questions, earn points and help others
