Question about Logitech Dexxa Joystick
I cannot find the connect port for my jostick for windows xp
  • 75 Answers
Does it have a joyport connector? If it has, you need a card for it, some soundcards come with it. Their not expensive. Have a nice day.
Posted on May 26, 2011
I have loaded USB 2.0 Driver but System could not detect that USB 2.0 Port when I connect USB 2.0 device to all six USB Port. I am having DG31PR Motherboard. I checked in BIOS setup. High speed port enable...
You have not mention what Operating system is on your PC.
For Windows OS XP, you just have to install at least XP Service Pack 2 or higher... and the USB 2.0 ports will function. For Vista & Win 7 OS, the USB 2.0 drivers is in the Operating System when you install Windows.
Hope it helps.
Jul 13, 2011 | Intel DG31PR Motherboard
I have APIOTEK EC-0008 serial express port card RS 232 it is not getting installed on my dell windows XP enviornment what is the reason
have you installed drivers for the card, as windows might know what it is but it wont be able to use it till the drivers are installed click below onto what version of windows you have and download the drivers
EC-0008
Windows 98/M2/2000/XP/2003
Windows Vista 32/64bit
MAC 8/9/OSX
Linux RedHat 7.3/8.0/9.0
Mar 16, 2011 | Port Designs Best Connectivity RS-232...
Pride victory and pride jazzy will not charge the batteries and when plugged in. The inhibit function seems to not be working either.
Bad charger port on joystick only fix is to replace joystick or if it has a seperate charger port underneath the jostick that has to be replaced
Aug 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
How can I share my HP officejet 5610 all in one printer that is connected to my desktop that has windows XP with my windows vista laptop?
1. Unplug your USB cable from the back of the Windows XP PC and plug the USB cable directly into your Windows Vista PC.
2. The Windows Vista drivers for your printer should be automatically loaded and your printer will be installed on your Windows Vista PC. If this was successful, skip right to step 3.
If step 2 is not successful
i. Download the Windows Vista printer driver for your printer from
the manufacturers website.
1. If your printers manufacturer has not created a Vista driver
yet, retry step 2.
ii. Install the driver on your Windows Vista PC. During
installation, youll be prompted to connect the printer to your PC.
Choose the option to proceed with installation without connecting the printer.
3. After installation is complete, open the Printers icon in the Windows Vista Control Panel.
4. Right-click on your printer that was just installed and choose Properties.
5. Navigate to the Ports tab.
6. Click Add Port, then select Local Port, then click New Port.
7. For the Port Name, enter the exact network path and share name of your printer. (ex. - \\HOMEPC\Printer2) 8. Click OK and make sure that this new port is selected with a check in the checkbox.
9. Click Apply and then OK to close the printer properties.
10. You should now be able to print from your Windows Vista PC to a shared printer located on your Windows XP PC.
Jun 17, 2010 | HP Officejet 5610 All-In-One InkJet...
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers...
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Lan connection!
is the lan port on the motherboard?
if yes, is the lan port turned on in the BIOS?
Does XP detect the port?
If no, check if BIOS setting is on.
May 17, 2009 | HP Vectra VL400 P3 Skt 370 Motherboard...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Refuses to print in XP - no error messages
Try going to 'add & remove hardware'. Remove the COM ports. Reboot your computer. Windows should find your hardware and install the COM ports. If not, add the COM ports manually. Leave the printer COM port settings on COM port 1 or COM port 2, whichever you prefer.
Jun 24, 2008 | Datamax Prodigy Plus Thermal Printer
Can I use the PDC 640CF camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will not be able to use the serial port to download your photos. Only USB port downloads are supported under Windows XP for the PDC 640CF camera.
Sep 14, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Logitech Dexxa Joystick Logo
90 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
