Question about HP Office Equipment & Supplies
Hi there. I have just purchased the deskjet f2275 and have attempted to install it 4 times. I have followed all prompts and each time it finishes with ''it is not digitally signed. Contact hardware vendor.
    Master:
  • 638 Answers
Right click the my computer icon, then click the printer properties, a system properties window will pop up, in that click hardware, then click driver signing,--
ignore ,install the software anyway and dont ask for my approval.
its done you can use your printer now.
Posted on Aug 16, 2008
Im looking for a driver for Hp deskjet 825c for windows 7 in south africa
Use the Deskjet 830C/832C drivers. I have a Deskjet 825C and the Deskjet 830C/832C works fine on my Windows 7 64 bit OS. It will work with the 32 bit version as well.
Previously I had Windows Vista installed and found the Deskjet 830C driver worked ok with it as well.
1. Start, Control Panel, Devices and Printers
2. Click Add a printer
3. Click add a local printer
4. Selct Use an existing port
5. In the drop down list select USB001 or 002 or 003, which ever appears. It should say "(Virtual printer port for USB)"
6. click next
7. On the install the printer driver screen under manufacturer select HP
8. Under printers select HP deksjet 830C/832C
9. Click Next
10. If prompted for Which version of the driver do you want to use?" select "Use the driver that is currently installed." and click next
11.Type a name for the printer int the text box for printer name:
12. Click next
13. If you want other computers on your network to be able to share this printer select "Share this printer..." and click next.
14. click print a test page.
15. Click finish.
Download Driver...... HP Deskjet 825c Printer Drivers
Read More help... HP Printer Support
Thanks,
Aug 18, 2014 | HP DeskJet 825c InkJet Printer
I WANT TO INSTALL MY HP DESKJET D2660 PRINTER IN MY COMPUTER
Hi luissdomingo,
To Install your HP DESKJET D2660 PRINTER,
Insert the driver (disc), then click run. its automatically install, then once have prompt Finish, just click then you can now use your HP DESKJET D2660 PRINTER.
If you dont have HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
Hope this helps.
Thank you for using Fixya.
Sep 07, 2011 | HP Office Equipment & Supplies
How to download installer without the cd?
you can install printer with window basic driver but this printer is new so window do not have the default drier for this printer you need to install driver from internet and then install your printer, follow this step to install printer and download drivers,
1. click this link to download driver for your HP F4100 printer FROM HERE.
2 select your printer model.
3. select your operating system.
4. then download the HP deskjet full feature software and drivers.
5 when download complete run the setup file to install driver for your printer.
6 do not plug the usb cable to your computer until setup prompt you.
7 follow the onscreen instruction which is coming on setup page.
8 and your printer is install and ready to use.
Thank you for using fixya
Regards
Manish
Jun 09, 2010 | HP Deskjet F4100 All-In-One InkJet Printer
I bought a hp deskjet f4400 from best buy and tried to in stall and it would not let me install
Dear friend please follow the step.
1. start PC and run the printer driver cd.
2. after a while your system ask your printer, thenm you connect in in USB connector then plug in for power connection. Wait for while, your system auto detect the printer , that time you received some Msg just read that all and go as per instruction.
3. Finish installation.
4 restart your system.
5 . 1st gives test print from printer properties option.
After these hope you seen good working printer with you.
Waiting for your feed back.
Jan 30, 2010 | HP DeskJet F4280 All In One Printer InkJet
Unable to install HP F380 drivers on Vista
well first of all uninstall the driver or drivers by going to the Control Panel, programs etc, if there driver is installed . Reboot, Now can you try another usb lead ? http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=&cc=us&lang=&product=1128296 now look at the post called Critical Update to Correct a PC to Printer Communication Issue download the HP Full Feature Software and Drivers install and connect the printer when prompt. Regards GeWiz
Jun 15, 2009 | HP DeskJet F380 All-In-One Printer
Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
Sep 24, 2008 | HP DeskJet F380 All-In-One Printer
Problems in Downloading & installation of Driver 640c.
Hi Deepak,
I think you have downloaded the driver for windows XP 32 bit OS, and i think that your PC supports Windows XP 64 bit Operating System.
Click here to download the software for Windows XP 64 bit Operating System.
DOWNLOAD (x64Drv5.64.0.17.exe)
Installation Instructions: USB Connection
1. Download the x64Drv5.64.0.17.exe file.
2. Once downloaded, choose Open or just run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below.
Note: There may be a long pause between each of the steps below.
4. Choose Direct Connect.
5. Power on the printer, and connect it to the computer when prompted.
6. The "Found New Hardware Wizard" will be displayed.
7. Select No, not this time.
8. Select Install the software automatically (Recommended).
9. Depending on your product, you might see one or more Windows' warning screens.
10. Click Continue anyway or Yes each time these Windows warning screens appear.
11. Click Finish.
12. Reboot your computer (Highly Recommended).
Installation instructions: Wired and Wireless Network
2. Once downloaded, choose Open or just Run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below:
4. Choose Network.
5. Choose your printer after the installer has identified it on the network.
11. Click Finish.
Thanks
Rizz
Jul 26, 2008 | HP DeskJet 640c InkJet Printer
Lost my installation CD and downloaded the software from HP but doesn't work
To register .dll files follow these steps: 1. Click Start, click Run, type cmd in the Open box, and then OK. 2. At the command prompt, type the following commands, and press ENTER after each command:
regsvr32 /u sccbase.dll
regsvr32 /u slbcsp.dll
exitNote Click OK if you are prompted.
3. Restart your computer. 4. Click Start, click Run, type cmd in the Open box, and then click OK. 5. At the command prompt, type the following commands, and press ENTER after each command:
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
6. Restart the computer.
Mar 10, 2008 | HP DeskJet 3940 InkJet Photo Printer
Hp deskjet 656c vista version
The driver you need is located in Vista already. Please follow these instructions from HP on how to install your printer under Vista.
Jan 23, 2008 | HP DeskJet 656c InkJet Printer
Will not load toolbox when clicking service tab
It's suggested to un-install the software & reinstall. Follow these instructions. Some files are corrupt & need to be re-installed.
Disconnect the USB cable from the printer only.
Insert the printer CD.
When prompted, click Remove and wait for the software to un-install.
Click, Finish to complete the un-install process.
Click, Yes when prompted to restart Windows.
Windows needs to be restarted for the changes to take effect.
Wait for system to fully finish loading.
Do not plug in the USB cable until instructed to do so.
Load the HP printer CD. Follow CD's instruction for install.
When completed re-start the system even if the software
has not instructed you to.
Check if the service tab function?
Please post back if the has failed!
& please vote...
Dec 12, 2007 | HP Deskjet 5940 Photo InkJet Printer
Ben Johnson
