Question about Bose Battery for SoundDock Portable Digital Music System - Black
Hi.. I have a bose wave ipod docking system.. the sound is amazing.. or was... until a few weeks back when i noticed that in order to hear my ipod... i had to tweak the ipod a little on the docking tray,,,2 weeks back... the bose speaker didnt work... when i turn it on.. I get this thump thump thump sound from the bose speaker.. any ideas ? can u help ? thanks .chris p.s... I am in ireland and my bose speaker is from USA.
  • 340 Answers
Are you using a voltage adapter of some kind to convert the ireland standard 220VAC to the USA standard 120VAC that this device uses? Over voltage can deplete an electronics life very quickly.
By the sound of the "thump-thump-thump" noise emitting from the device, you may have a broken ipod dock connector, or a short somewhere in the connector/wiring/device itself, or the ground has failed.
By the description of having to "tweak" your ipod to hear it, it sounds like you've slowly broken the dock connector. Check to see if it moves easily, or if you can hear anything loose.
This is more than likely fixable, but it's probably easier to replace the device than to fix a broken connector.
Posted on May 26, 2011
I pod charges, plays, but no sound
Easy, I had this problem too. The reason it isn't playing is because its not in all the way. I was getting very frustrated with this, so I kept trying to push it onto the dock to get it all the way down.
Solution:
1. Play a song on your ipod/iphone so you can hear it through the device.
2. Connect your ipod/iphone to the docking station(Bose) so that you hear the chime(This lets you know its charging).
3. Pick up the docking station and firmly press the ipod/iphone down on the connector.
4. Keep pressing it and wiggling around until you hear the music begin to play through the docking station.
It may take a few tries, but you will get it.
Hope this helped!
~ Jake
Oct 05, 2009 | Bose SoundDock digital music system...
Bose Portable sound dock remote not working with iPod Classic
I have the same problem with mine. Called Bose Belgium and waiting for answer but it seems there's nothing to do.
Wait and see
Sep 21, 2009 | Bose SoundDock Digital Music System for...
My bose ipod speakers are making a knocking noise and not charging my ipod
bose ipod speaker been turned of for a few months just plugged it in making a knocking noise is this normal
Jul 11, 2009 | Bose SoundDock® (Black) Docking Station...
My bose dock has power but no sound the remote dont work but it charges the ipod wot can be wrong
i spoke with bose tech support today because my docking system had no sound...everything else was fine, but no sound. they told me to take the battery pack off of the back, then reset my ipod by holding down the center button at the same time as the menu button for about 5 seconds (the apple icon will display), then reconnect the battery pack to the back of the dock and retry. it worked! good luck.
Jul 07, 2009 | Bose SoundDock® (Black) Docking Station...
Does the new bose dock station charge the new ipod touch (32g)?
i have the same problem with the old docks not charging my ipod touch and yes new bose docks and ihomes charge the 32g ipod touch
May 15, 2009 | Bose SoundDock digital music system...
Bose Ipod docking station not working!
Make sure the power supply is connected properly. If the power supply is connected upside down or sideways, the system will make a thumping noise, or will not play at all. However, no damage will be caused by connecting this wire incorrectly.
Mar 29, 2009 | Bose SoundDock digital music system...
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Cannot connect iPod to Bose Lifestyle V20 System
On the side of the V20 control box (with all the inputs/outputs on the back), there is a small jack for an input directly from the headphone output from your Ipod - so all you need is a male/male ended cord (like the one used in vehicles with AUX inputs) and plug in - SIMPLE!
ENjoy
Jan 04, 2009 | Bose Lifestyle V20 System - black Theater...
Problem with Ipod Nano 3d generation and Bose Soundock
Try other iPods - if they work with no problems it is a problem with the iPod software, connect this to iTunes to get it updated, and also try a soft reset (hold down menu+center buttons for about ten seconds) if you still get issues, contact Bose.
Dec 10, 2008 | Bose SoundDock Digital Music System for...
Bose Battery for  SoundDock Portable Digital Music System - Black Logo
537 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
