Question about Epson Stylus NX200 Printer
Have an Epson NX200. Need to change ink cartridge but ink carrier will not position so I can open it.
    Scholar:
  • 56 Answers
Usually you can move it manually with your hands .Turn off first your printer .once it turns off pull the carrier, pull the white tape gently to the center and just replace it ink cartridges there. Make sure its properly plug in .Once your done return the move the cartridge carrier manually from left to right 5x once your done you may now close the cover .(close it first ) And checked if its going to the center once you open the cover .
Hope it help thanks
Posted on May 26, 2011
Replacing cartdiges in sx 200 epaon
Press the ink button on the control panel repeatedly. This will work if at least one cartridge is completely out. With the scanner unit open, then the first press of the ink button will move the cartridge carrier to line up the empty cartridge with an "empty cartridge" mark on the printer. Each subsequent press will cause the next empty cartridge to line up with the mark. Once all of the empty cartridges have been indicated, the next press of the ink button will bring the cartridges into the replacement position.
If you want to change a cartridge when none are empty, you need to enter the Epson Toolbox (with the printer in a Ready state - scanner unit closed, etc). Then use the software to set the printer to change the ink cartridges. When prompted by the software, open the scanner unit and follow the directions for changing the ink cartridges.
If the cartridge carrier isn't moving when you press the ink button, look for anything blocking the path of the carrier. Even small pieces of paper could stop the mechanism. Use a flashlight to check the corners. (You may want to unplug the printer and try moving the cartridge carrier by hand to check below it.) Some models have the cartridge carrier run on a plastic strip that can come out of the guide on the back. Move the strip back and up and down until it is repositioned.
I hope this helps.
Nov 12, 2011 | Office Equipment & Supplies
I need step by step instructions showing how to change an ink cartridge on and Epson NX110 printer
If the printer is out of ink in one or more cartridges (the ink light is steady), then with the printer on, lift the scanner unit and use the support to prop it up. Press the Stop button and the (first) empty cartridge will line up with the No Ink symbol on the printer. Press Stop again and the next empty cartridge will be moved to this symbol. Continue to press Stop until the cartridge carrier moves to the ink replacement position (depends on how many cartridges are empty). This is on the right side of the printer. Wait for the cartridge carrier to stop moving. Do not touch the white cable while changing the ink.
Next remove the first ink cartridge by pressing the two tabs towards the center of cartridge and pulling it straight up. (One tab is close to you and the other is closest to the printer.) Take your new cartridge for the slot and shake it four or five times. Then remove the cartridge from the package. Do not touch the green chip. Remove the yellow tape from the bottom of the cartridge. Next rotate the cartridge so that the nozzle is down and facing towards the inside of the printer. Then push it straight down into the slot until it snaps into place. Repeat these steps for the rest of the empty cartridges.
Once all of the empty cartridges have been replaced, lift the scanner unit and push the support to fold it. Close the scanner unit. Press Stop to start charging the ink system. Wait until the Power light stops flashing and remains on before turning off the printer or sending a print job to the unit.
If the Ink light continues to flash, open the scanner unit and press Stop. Press down on the cartridges to make sure that they are completely seated in the cartridge carrier.
If the ink out light is flashing or not lit, you need to use the Epson Utility to change the ink. This is part of the full software from Epson. For Windows right click on the printer icon in the taskbar (bottom right of the screen). Then select Printer Settings and click on the Maintenance tab. For a Mac, open the Applications folder and open Epson Printer Utility 3. Select your printer (if you have several Epson printers listed). Then click OK. (You will need to launch the utility before you open the scanner unit.)
The documentation for the Epson NX110 is available here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1663277658.1305218830@@@@&BV_EngineID=cceeadfdielfldicfngcfkmdhjidfmh.0&cookies=no&infoType=Doc&oid=128284&prodoid=63084353 .
I hope this helps.
May 12, 2011 | Epson Office Equipment & Supplies
I have an Epson Stylus NX200 and need to change the ink. When I open the scanner lid the ink cartridges are on the far right and I cannot reach them in order to remove them. Turning the machine off and on...
You will need to press the STOP button for the cartridge carrier to move to
the ink change position.
Additional information can be found at Epson support page.
Click on link below and mouse to Remove and Install Catridges at bottom of web page.
http://files.support.epson.com/htmldocs/nx200_/nx200_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=NX200UG.1.100.html
Mar 10, 2011 | Epson Stylus NX200 Printer
Please give us step by step instruction on how to change ink cartridge?
  • Turn on your printer and raise the lid or press the cartridge changing button.
  • Wait for the cartridge carrier to slide out.
  • Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Close printer cover.
  • Mar 03, 2011 | Epson Stylus Multifunction Inkjet Printer/...
    How to I change ink on epson printer NX127 I cannot get the cartage out Can you show me the picture of the cartage ink holder with the lid up
    First make sure the printer is on, then open the printer cover and the cartridge cover. Then press the Stop button. Assuming the printer has identified a cartridge with low ink, that cartridge will be moved to the replacement position; then the power light will flash. Squeeze the tabs on the ends of the cartridge together and lift it up. Unpack the new cartridge and remove the tape carefully. Then press the new cartridge into place until it clicks.
    If more than one cartridge has low ink, the leftmost one will be in the replacement position when the cartridge carrier stops moving. Press Stop again to advance the carrier to put the next low cartridge into the replacement position. Then press Stop again to have the printer move the cartridges to the home position and charge the print head. When the lights go out or stop flashing, close the cartridge cover and the printer cover.
    If the cartridges aren't low on ink, then use the Epson printer utility (under the Maintenance tab) to start the process.
    For pictures of the Epson printer during ink replacement see: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1558177770.1297529968@@@@&BV_EngineID=ccdcademkhmjkgicfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=150187&prodoid=63088089&foid=157388 . Alternataively, see http://files.support.epson.com/htmldocs/nx125_/nx125_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=Ink.7.1.html .
    I hope this helps.
    Feb 12, 2011 | Epson Office Equipment & Supplies
    How do I change the ink cartridges?
    Step 1:Purchase an ink cartridge made specifically for your printer. Step 2:Turn on your printer and raise the lid or press the cartridge changing button. Step 3:Wait for the cartridge carrier to slide out. Step 4:Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Step 5:Carefully remove the tape from the ink opening on the bottom of new cartridge. Step 6:Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. Step 7:Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. Step 8:If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge. Step 9:Close printer cover.
    Jun 13, 2010 | Epson Stylus C86 InkJet Printer
    HOW DO I CHANGE MY INK CARTRIDGE?
    1. Step 1 Purchase an ink cartridge made specifically for your printer.
    2. Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
    3. Step 3 Wait for the cartridge carrier to slide out.
    4. Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epsonmag-glass_10x10.gif printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
    5. Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
    6. Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
    7. Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
    8. Step 8 If you have an Epson printermag-glass_10x10.gif, close the cartridge holder lid and press the cleaning button to charge the cartridge.
    9. Step 9 Close printer cover.
    Thanks
    Apr 24, 2010 | Epson RX620 All-In-One InkJet Photo...
    How do i change ink cartridge
    While cartridge installation varies somewhat between brands and models, these general instructions apply to most major brands:
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Apr 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
    Change ink
    Usually, with an inkjet printer to change the cartridges, open the cover and then press the power button - or the other button, if there is one. Don't be afraid to press buttons ..
    The cartridge carrier will then move from its 'parked' position to a more central, accessible position. Unclip the cartridge retaining clip and simply lift the cartridge out. Virtually all inkjet printers work on this principle.
    Don't try and manually force the cartridge carrier along from its parked position otherwise you will cause damage.
    May 17, 2009 | Epson Stylus C20UX InkJet Printer
    I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
    buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
    Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Epson Stylus NX200 Printer Logo
    198 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
