Question about ADIC Scalar i500 Tape Drive
Can I patch my FC tape drives directly into my FC switch or can I only attach the tape drives directly to hosts? I don't have FC I/O Blades in this i500.
  • morrisj663 May 26, 2011
    Thanks for the input. All the doc's I've dug up explain how to connect the drives to the Scalar FC I/O Blades, and then configuring its connection to the fabric. Left me wondering about the intended connection topology of the tape drives themselves. I'll keep digging... Thx again!
    Brigadier General:
  • 8,546 Answers
I'm not an expert on current technologies but any FC device should log in to any FC switch. Make life easier on yourself and zone the port instead of the WWN.
Posted on May 26, 2011
Stihl hl75 pole trimmer. Blades don't move. Cable turns when cutting end is off machine, but will not drive blades when it is attached. Anyone have an idea as to what's going on?
More than likely a gearbox problem in the cutter head. They can break teeth on the gears and also have delicate needle bearings than can wear if they are ungreased. Maintenance is paramount on these moving parts.
Jul 26, 2012 | Stihl Hl75 Line Trimmer Owners Manual
Fiber channel backup problems
why ask here.
why not ask HP.com.?
start here, ask at HP.
http://h30434.www3.hp.com/
May 09, 2017 | HP StorageWorks MSL4048 1 LTO-4 Ultrium...
I want to set up a server and 10 computer LAN without an internet connetin involved
just hook it up, you have no router involved so it will have no internet connection.
Just connect all the PC's to the switch using straight through patch leads and assign the IP address manually as DHCP will not run on the switch.
you don't need a default gateway address as there will be no routing. Just set the IP addresses to;
192.168.0.1
192.168.0.2
192.168.0.3
and so on for each host on the LAN.
Use the subnet mask 255.255.255.0 this will give you the address range 192.168.0.1-254
hope this helps.
May 03, 2012 | D-Link DES Computers & Internet
Lto-3 tape drive slow
Update with latest firmware / else get is serviced.
Dec 06, 2011 | Quantum PX502 (PRA22AAYF) Ultrium Tape...
I am unable to change the direction of the blades on my hampton bay fan. I am unable to locate the switch
Alexander, if you have a light kit on your fan, look just above where it's a attached to the bottom of the fan. There will be a 2 position slide switch on the side of the housing.. Up is for Winter operation, Down is for Summer operation. Turn the fan OFF and wait until the blades stop turning before switching the direction of the rotation.
Hope this helps you.
Jul 08, 2011 | Hampton Bay Heating & Cooling
I need the connections for the EQ100 between my my receiver and CD player. thanks, bob
Most people don't put EQ directly attached in between a source and the receiver. THAT is what a TAPE loop is for. Then it can be inserted or bypassed by the flick of a switch.
If you MUST. OUTs go to INs.
CD OUT to Audio IN; Main OUT to Receiver (anywhere BUT Phono) IN.
http://www.soundsclassic.com/listpix/audiosourceeq100bk.jpg
Traditionally, the EQ would be in one the tape loops and the D (and all other sources) would be attached to your receiver and a tape Deck would be on one of the EQ's Tape Loops so you would have flexibility to use the EQ with ANY source; and before or after a Tape Deck.
Bear in mind that an AVR (digital multichannel receiver) will NOT pass any digital audio to or through an EQ and that activation of a Tape Loop on an AVR disables all digital sources.
Jun 29, 2011 | AudioSource EQ-100 Home Equalizer
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
Hello, I have several DTF2 tapes that I would like to extract the files from. is it possible to hookup a DTF drive to a pc workstation and be able to see and extract the files? thanks raf
Yes, you will need a fiber channel host bus adapter (HBA) in the PC. Install the HBA in the PC and connect it to your fabric, and then zone it the same as you would zone a server.
If you don't have a fiber channel fabric, it might work if you connect the HBA directly to the tape drive, but you definitely will need a HBA.
May 04, 2011 | Sony DTF-2 GY8240FC Tape Drive
Scsi tape drive not recognized on the library
Please check your firmware on the tape drive. Update with X-Talk software that can be downloaded from www.quantum.com.
Apr 28, 2008 | Computers & Internet
ADIC Scalar i500 Tape Drive Logo
195 people viewed this question
Top ADIC Computers & Internet Experts
David Payne
David Payne
Are you an ADIC Computer and Internet Expert? Answer questions, earn points and help others
