Question about Huffy 12 in. Girls Disney Princess Single Speed Bike. Purple
Can't install seat - Huffy 12 in. Girls Disney Princess Single Speed Bike. Purple
  • WTF Chuck.....
    WTF Chuck..... May 26, 2011
    What part of the seat? The seat itself? or the seat post?
    Novelist:
  • 184 Answers
If the stem has a lot of holes going down it, you should have a round headed bolt and elastic stop nut that fits thr the frame front to back that holds the seat, BUT- some had a traditional clamp and bolt that just squeezed on the frame tube.
Posted on May 26, 2011
Carseat jammed to easy base 2
Try pressing down very hard on the seat while trying the release. If that does not work, call the manufacturer.
Note: if this does release, check the seat belt for damage before using again. Also check that the belt path used to install the base is/was correct.
-- Marc
May 23, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
My Seat Arosa car radio won't work after the battery went dead .
Normally put radio code in by holding the buttons as the numbers come up
Jan 13, 2018 | Cars & Trucks
I was wondering if it is safer to install baby's carseat in the middle rather than on the side
Yes, most manufacturers recommend installing your car seat in the middle of the rear seat to reduce the risk to your baby should a side impact occur. The farther your baby is from the walls of the car, the less chance that a physical hit will occur.
That said, it is still safe to install your car seat on the side, as may be necessary if you have two children in car seats.
Many law enforcement agencies offer free car seat installation inspections to make certain your car seat is installed correctly. Check the National Highway Traffic Safety Association website for local options: http://www.nhtsa.gov/cps/cpsfitting/index.cfm
Oct 16, 2012 | Safety 1st Baby Care
99 grand prix power seat problem
check for something jamming the track under seat , try havin son push seat forward while pushin switch . i dont know of a way to override the seat motor if its dead,,auto wreckers for seat replacement cheapest way to go they may even install
Feb 03, 2012 | 1999 Pontiac Grand Prix
Automatic driver seat broken, how to fix/cost
The back and foward movement uses the same motor. So if it moves one way but not the other it's most likely the switch. Try to blow it out or clean it out. If pop or somthing spilled on it you will prob. need to pull switch out and take it apart to clean contacks inside.
Nov 10, 2011 | 2005 Kia Optima
Hinge on quiet close stopped working
A lot of these slow closing toilet seats don't work well, so I suggest an alternative, Drop-a-Seat cushions. They stick on to the bottom of the toilet seat, allow you to drop any toilet seat, gravity does all the work, and the cushions absorb the impact. They're non-absorbent, stick on for easy installation (permanent yet removable), and are only $4.99. Check them out at www.drop-a-seat.com
Aug 14, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
To whom it may concern, I'm struggling to install
The Tethers are on the rear deck at the top
You have to pull the seat belts out a way as
you said & then when you get them through
or around the seat, however they go,you snap
back & forth till they lock. The same thing
you do while in the drivers seat with your seat belt.
When done the child seat is kind of sloppy
in my opinion. Not really secured down tight
I would suggest you get help from an experienced
person that has kids & those seats to install
Jun 27, 2011 | 2001 Chrysler 300M
To whom it may concern, I'm struggling to install our infant car seat in our Chrysler 300M, 2001. The base comes with hooks to attach to tethers or latches which should exist by the seat belt...
I would take the vehicle to a place where they install infant seats,because you can't put a price on a childs life.....hope this helps......cheers.
Jun 27, 2011 | Chrysler 300M Cars & Trucks
Seat seized possibly something in track because one side works frely
Thiers gearboxes and clutches, in the seat base it's not really designed to be repaired and the best way to fix it is ti buy a used seat base at a salavage year and even on Ebay. Most Gm seat bases are nearly tyhe same as long as the model year is close as the same seat base fits alot of different vehicals. the manual seaty base will also fit if you want to do that as it'll fit too as long it's from about the same vehical. The salavage yards use a Hollander catalog that lets them figure out what willl work. The power and manual seat bases interchangwe as the same vehicals are made both ways. Some times you can get the seat base to go back together, like a cable came out of it's holder but once they start giving troble repaired ones mostly don't stay repaired very long. New ones are expensive and The Dealers don't stock them. I used to work in a rent a car place and peaple would rent one for a day and come back and say the seat wasn't working right and it was'nt even installed all the way. They just rented the car to take the seat base but their was no way we could prove it.
Jun 21, 2011 | 2004 GMC Envoy
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Huffy 12 in. Girls Disney Princess Single Speed Bike. Purple Logo
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
