Question about Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers
HOW DO I RE PROGRAM A KEY PAD GARAGE DOOR OPENER REMOTE CONTROL. GENEI CO. MODEL ACSDG FCC ID: B8Q ACSDA CANADA 2133 101 575 FCC Part 15 IC RSS/CNR 210
SOURCE: garage door opener key pad not working
so i spent the better part of this morning trying to figure this same thing out... here's what I found.
You need to identify the serial number, which is found on the unit hanging from the ceiling... it will be like a 13953970. I found mine behind the lamp light protector thing. NOT the back with the stickers. 41A5021 is actually not the number that is important.
then go to www.managemyhome.com its a website ran by sears. you have to register, for free. then go look for manuals, in one of the tabs running across the top of the site is a choice for manuals. then search by Craftsman then enter the serial number.
then pull up the owners manual and check out the instructions.
** i found out that the old house i bought did not actually have the same keypad opener as came with the craftsman. so i had to closely inspect all sides of the internal keypad opener (not the one outside) and find another serial number. then i went and got the manual from www.managemyhome.com and realized i needed to add a new 9-V battery before I could proceed. So now i'm heading out to walmart to get that.
after a frusterating morning of service number and internet searches I hope after I get this damned battery the clouds will part and god will shine some luck on me.
goodluck to yourself!
Posted on Sep 29, 2008
TJBENGR
  • 121 Answers
SOURCE: Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Posted on Apr 21, 2008
  • 3197 Answers
SOURCE: Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Posted on Nov 21, 2009
  • 3197 Answers
SOURCE: i have a quantum model 3212 serial #3000...fcc id
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Posted on Feb 23, 2010
  • 3197 Answers
SOURCE: GARAGE DOOR OPENER, LOST REMOTES,
Sears sells a universal conversion kit.
Craftsman - Model #00953751000
Posted on Dec 09, 2010
How do I reprogram auto remote for garage door
get ladder, press square button on back of motor, press and release opener button press again to confirm operation
Oct 16, 2014 | Building Materials
I have bought a second remote control craftsman 315 918191 i have remote device install with my crafftsman door opener there is no learn buttom on either device what can i do thank you
Post the model number of your opener. It is on the end of the motor unit nearest the door. It starts with 139. Also post the model number of your new remote. It should also start with 139.
Mar 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears Canada 139.53681B FCC ID hbw1255 I DONT HAVE MANUAL & NEED TO RESET REMOTE TO OPEN DOOR FOR GARAGE. CAN ANYONE HELP? V
You don't normally ever need to reset the remote but.....................
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and hold the button on your remote while you press and immediately release the smart/learn button. If this doesn't work either your remote or the receiver has quit working. Make sure the battery in the remote is good.,
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
I don't have the manual to re-program my keyless entry pad and cannot use it. The previous owner did not keep the manual and on occasion, he comes back and goes into the garage. He is in his mid 80's and...
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
You may need help with this if you cannot get up on a small ladder.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a garage opener where the remote is not working. I have changed the battery, but it is still not functioning. Craftsman FCC ID HBW1136
Make sure the light in the wall control is not blinking. If it is press and hold for 3 seconds the button with the lock icon. If this isn't the case your remote may have failed.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Clicker Model No. KLIK 2 can not be programmed to operate a Chamberlain door opener FCC ID HBW 1127 w/Merk 1/2 HP motor (Model No. 929 ?) although I have followed the instuctions furnished with the...
If you follow the watch the video and follow the instructions on this site and still cannot get your opener to program then you have a bad logic board.
http://www.chamberlain-diy.com/doityourself/pages/accessoriesmodeldetail.aspx?modelId=1478
Nov 15, 2009 | Universal Garage Wireless Keyless Entry...
Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers Logo
1,090 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
