Question about Nintendo Wii Console
Hi i have recently got a lg surround system without a manual, i think all the speakers are set up correctly as i have done a sound test on it and they all seem to make noise however i am having trouble finding were to put all the wires to set it up threw my tele/dvd. i have one wire correct ( i think) the AUDIO OUT wire is in and sound is coming out of the small speaker however the other 4 standing speakers are notmaking any sound. any suggestions ?
  • Anonymous May 26, 2011
    i am gratefull for you pointing out what faults there may be however i have done a sound check on the surround sound and all the speakers are set up correctly, when u say i should have 2 RCA jacks on my tele and surround sound i have a scart that goes to a white yellow and red and another scart that goes to 2 black jacks that say AUDIO IN and AUDIO OUT and 2 yellow jacks that say VIDEO OUT and VIDEO IN. I have tryed numerous ways to put it in the back of the surround but only one seems to work, the VIDEO OUT jack is plugged into the CENTER and only the small speaker is working. I do not know the exact make of my surround system but the closest model i can find is the LG HT752TH, maybe this helps? thanks alot
    Sergeant:
    Novelist:
  • 159 Answers
You should have 2 RCA jacks on your TV and on the back of your receiver ... a white and a red. These are the left and right audio jacks. Generally, I hook up the audio out from the TV to the DVD player, then from there into the receiver ... this makes it easier to turn off the connection to your receiver if you want to use the TV speakers for news and whatever (by turning the DVD player off). Once the RCA cables are all hooked up, the information should have no problem transferring to your surround sound receiver. Now that the connections are all made, check the settings on your receiver. Make sure that you have the surround sound turned on, and that the receiver has all speakers selected (hunt through the menus and find the "dolby 5.1" or "THX" surround options and turn one on. This SHOULD resolve the problem.
If this did not repair your issue, make sure that all of your equipment that you are running through is all capable of surround sound (if you have a really cheap DVD player like me, it may not be able to handle surround sound). If your TV is surround capable (LCD, Projection, and Plasma TVs are usually all capable of this ... CRT tvs are not always capable) but your DVD player is not, hook your TV's audio RCA cables directly to your surround sound receiver and you should be set. If your TV and DVD player are not capable of Dolby or THX surround sound, then you will probably not be able to use that feature, so your satellite speakers might not work, but the main left and right should still work fine.
One other thing that I have had issues with in the past is the connections on the back of the receiver. If you are using speaker wire (a lot of newer systems have input jacks instead of wire because they are easier to deal with) then make sure you have stripped enough of the wire to make a good connection in the back of your receiver. If you have too little wire exposed, or if you have pushed the wires in too far, the insulator on the wire will block the connection. To be sure this is not the case, be sure that only the exposed part of the wire is sticking into the back of your receiver. Also, make sure that you are not trying to run too much wire between the receiver and the speakers -- if you have a 100ft wire between the system and the speakers, they might not be getting a strong enough signal to work -- you can buy a signal amplifier for your speaker wire, or you can use a shorter wire.
Most likely you have to find the settings in your menu and turn on the other speakers. If the sound test worked for all of the speakers, the connections are all good, and it is the system not telling the speakers to work.
Posted on May 26, 2011
  • Dave
    Dave May 26, 2011
    There is a link in the middle of this page to get to the user's manual for the model number you gave:
    http://www.lg.com/uk/support/product/sup...
    if you download the PDF and scroll down a bit, you should see a couple of diagrams of the back of the system. If this is (basically) the same as your system, we can work with it. If you have an HDMI output on your TV, the whole thing will be a lot easier -- just connect that to your surround sound system (according to the PDF that should be all the way on the right when looking at the back of the LG system). If you do not have an HDMI cable, you should still be able to work it. Just to the right of the center of the back (just a little to the right of the speaker jacks) you should see the [yellow] [red and white] RCA inputs for your system. Connect the yellow output from your "monitor out" to your TV to get picture. Then connect the red and white "audio Outputs" from your TV to teh "Audio Inputs" on the back of your LG. This should give you the option to make it work. Next you will have to go into your settings on your LG and make sure that your audio is set to "Aux" -- the input from the TV. According to the PDF, if you are playing a DVD or blue-ray or whatever from the LG, you should no have to worry about the audio as all of the connections are internal -- just make sure you have your LG set for DVD mode instead of AUX Audio.
    You should keep in mind where the sound should be coming from -- if it is from the LG, then you do not have to worry about the plugs -- just the Menu settings. If you are trying to get the sound from the TV (if your Cable / Satellite / DTV converter is plugged into your TV, then you will need to have everything set to take the audio input through the Aux audio input on the back of the system -- once again in your menu settings).
    If you are like me and don't mind a jury-rigged system, you can buy a converter plug from Radio Shack that combines the Red and White RCA cables to a 1/8" headphone jack and plug that into the "audio in" in the front of the system (according to the diagram in the PDF file). The cable itself has a headphone jack on one end, and splits in two (red and white) on the other end. I have one hooked up to my computer right now and can take a picture if I didn't explain it clearly enough -- it's just a pain for me to upload the photo.
    I really hope that helps ... good lusk!
  • 340 Answers
If you give the model number of your LG system I can find a manual for you.
Are you trying to hook up a TV/DVD through a headphone jack or two RCA plugs?
Most Tv's these days will support 5.1 audio systems but some have to be set that way, otherwise you'll only get sound from one or two speakers. Check the settings menu on your television for anything labelled "sound output".
Also, check your sound system, it may have options for stereo/5.1 surround/etc.
Please reply with the model number of your system (usually on the back/bottom of the unit) and I will find a manual and be a little clearer on instructions.
    i do not know the make of my surround as i got it 2nd hand, if you look on the 2nd soloution to my problem that somebody has commented i have explained the problem in more detail, thank you for trying to help.
I have a problem with the lg ht357sd home theater system.i just bought it two weeks ago.For a while all the speakers were working but since five days ago it is only the two front speakers that work,the...
What are you playing in it? If you are playing a cd, the system will default to playing the sound only in stereo. You can manually select a surround mode if this is the case.
Jan 08, 2013 | LG Audio Players & Recorders
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
LG HT752TH Surround sound system rear x2 and centre speakers do not work even tho connected and tested correct.
They will work only if the source signal is itself 5.1. If it's stereo then you must convert it to 5.1 using the Virtual sound setting (press VSM to access it and select 5.1).
Sep 02, 2010 | LG LH-T754 Theater System
I'm having trouble with sound when i try and install a surround sound system. This is the second system I've had that my lg would not play sound
Firstly you must have the remote typically to set the speakers up or there is a combination of keys to do this but usually some functions cannot be changed without the remote.
Second, the surround sound playback can only be played if the sound that you are listening to has the surround sound track, otherwise you may not hear hardly anything when your device is set to the wrong function.
The speakers must also match the surround sound system otherwise you may not hear anything at all.
Remember: A 5.1 System is 5-speakers,   A 7.1 system is 7 speakers!
The speakers should be marked for which place they belong LF= Left,Front...etc.
Jun 12, 2010 | Audio Players & Recorders
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Center speaker and wireless rear speakers have no sound
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
Jul 07, 2009 | LG LHT854 Theater System
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Nintendo Wii Console Logo
777 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
