Question about Compaq Presario 5000 PC Desktop
I need to remove my hard drive and don't have the instructions. It is Presario S5200 CL
    Sergeant:
    Novelist:
  • 159 Answers
Here's an intro to computer dismantling / rebuilding :-)
1. Unplug the computer from the wall 2. Be sure you are not carrying a static charge (work in a place with no carpet, try not to wear wool while working on the computer, touch a grounded metal object like a faucet -- any static sparks can cause damage to your computer) 3. Open the computer case -- sometimes there are screws that you will have to take out, but most newer systems have a release lever to open the case. Some computers force you to unplug everything from the back to get the cover off the case others do not. Just make sure there is no power going to the system by removing the power plug. 4. Find the drive that you want to remove. Floppy drives / Zip drives / CD / DVD / Blue ray drives are easy to spot as they still look the same from the front. Hard crives are usually located below this, and tend to be a bit smaller in size than a CD drive (usually 3.5 inches wide). 5. Unplug the ribbon cable and power cables from the drive. Make sure that you pull the ribbon cable straight out (so you don't bend the pins) -- there is usually a small piece of plastic connected to the plug to help you remove it correctly -- pull the plastic, not the cable. Power wires inside computers tend to have a tab you have to push down to release the plug ... kinda like a phone cord, just push the tab and remove the cable. 6. Once the drive is totally unplugged, look for a couple of screws connecting it to the case -- a lot of newer systems use sliding components that latch instead of screws these days, so the drive might just slide right out without a problem, but if it does not then look for screws. 7. Once the drive is out, you can replace it by following these steps in reverse. Just remember to be careful to screw the drive in it there were screws, or make sure it latches if it slid out (if a drive is not attached properly to the case it can -- very rarely -- cause extra vibrations that can cause damage)
These directions should work for any drive in any computer. The components are all pretty much the same (though Compaq has a habit of making their drives and plugs different sizes than standard so you have to go through them for upgrades) Remember as you work that you should not force anything ... if a plug is not working with a minimum of pressure, make sure it is lined up exactly and try again. Bending pins on a drive will ruin the drive ... pushing too hard can even force the pins into the drive, also ruining the drive. Good luck!
Posted on May 26, 2011
    Scholar:
  • 73 Answers
You can get your computer manual & user guides on HP Compaq website. Here's the download link for your manual:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=364168&lang=en&
Note: Just click on Compaq Presario S0000 / 8000 series User Guides. There's a step by step info how to remove computer parts.
Good luck,
Ryan
    Master:
  • 956 Answers
Hi go to the following:
Compaq Presario CQ5000 Desktop PC series (discontinued) - HP
Compaq Presario Home Desktop PCs. Compaq Presario CQ5000 Desktop PC series ...
h10010.www1.hp.com/.../12454-12454-3329737-89304-89304-3884644.html
Remove the hard drive from a Toshiba E-studio 450 copier
Dont dispose the HDD if the HDD is still in working condition. U can reuse it on computer, or backup on others copier...
Jun 19, 2012 | Toshiba e-Studio 350 Copier
Compaq Presario v4000- how to do a factory reset?
umm without a drive this is just a netbook install a drive and then you can proceed compaq's don't work well without an operating system which is on the hard drive
or is the disk drive the cd drive reader that you are referring to
May 29, 2012 | Compaq Presario V4000 Notebook
Driver/software needed for fuji S5600 for windows 7
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 20, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
Have lost my Driver CD for my Fujifilm S5500, bought in 2002. My picture download program has disapeared, what are my opptions?
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as iPhoto on Mac and Windows Photo Gallery or Picasa ( http://picasa.google.com ) on Windows.
Sep 16, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
I don't know the problem with camera or usb
Try NOT connecting your camera to your computer.
Sep 03, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
How to take laptop hard drive out ?
Turn over the laptop. you should see a rectangular lid with usually two screws holding it down. remove the screws. lift up the lid and slid the hard drive away from the connector. they are usually mounted in a tray. remove the four screws holding it in the tray. mount the new hard drive the same way as the old one was in the tray. then reverse the removal instruction to reinstall it. careful you don't lose any of the screws. this is general instructions for most laptops. my old dell inspiron hard drive mounted from the side of the case but again only two screws held it in.
Jun 14, 2011 | Compaq Presario 700 470024-192 Notebook
I don't know how to remove the lens for fujifilm s3200
You don't.
It may look superficially like an interchangeable lens camera, but it's not. The lens is permanently fixed to the camera.
May 25, 2011 | Opteka (OPT2XTE5000) for Fuji Finepix...
Compac presario cq56-115dx hp wireless assistant does not work
You don't need HP wireless assistant. You can remove it and enable windows zero wireless configuration to manage your wireless signal. Easier, and less complicated. Message me back to get instructions.
May 17, 2011 | Compaq Presario CQ56-115DX Laptop
Remove hd compaq presario 1621
I think it is the same as HP. When you undo the cover just pull it right out by the small plastic. No screws holding the drive.
Apr 21, 2010 | Compaq Presario Notebook
Remove hard drive in compaq presario laptop f572us
Please see link for Detailed instructions. Its simple as unscrewing a few screws and sliding out the hard drive.
Apr 01, 2009 | Compaq Presario F572US Notebook PC
Compaq Presario 5000 PC Desktop Logo
118 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
