Question about Canon PIXMA MX310 All-In-One Printer
Scan problems with Canon MX310
Just received my Canon MX310. Downloaded both CDs and tried to work with machine.
Copier and printer work fine but when try to scan an error message shows up no connection with scanner or scanner not turned on.
Like I said the printer works fine so I know the computer is working to the printer but why not to the scanner?
Thank-You
  • 9 more comments
  • levolu Aug 29, 2008
    same problem with me. i tried many times but scaner still not working.
    can some one help? much appreciate.
  • Anonymous Sep 25, 2008
    Have the same problem. Pinrter and fax work but scanner does not. Message reads scanner not connected or not turned on.
  • robsternthal Oct 01, 2008
    Same problem. I know its not USB b/c Scanner used to work with same USB cord previously.
  • Anonymous Nov 28, 2008
    I have the same problem.
  • Anonymous Dec 16, 2008
    I have the same problem... Kinda. When ever I try to scan my art on the computer, it doens't do anthing. The screen stays the same, not freezes or anything. I know it's connected, and the printer, fax, and copier work perfectly.
  • terisawyer Jan 23, 2009
    My MX310 won't scan either.  I push the scan button and it then shows a screen that is black or color scan.  It then changes to "scan mode" on the screen.  I press the color start button and nothing.  No error message.  Nothing. I tried switching the USB cable.  I think these printers just really don't scan at all.  Any solutions?
  • Anonymous Feb 26, 2009
    Same problem here.
    I push scan then start in colour and nothing happens.
  • Anonymous Mar 29, 2009
    scan mode in the scren but nothing pass
  • Anonymous Apr 26, 2009
    Same As His
  • Anonymous May 14, 2009
    same problem here. copying, faxing, printing all fine. scanner is not working. brand new computer, printer/scanner, and USB cable. driving me nuts!!!
  • keitha1234
    keitha1234 Mar 01, 2013
    Darius - thanks for the solution - it worked for me. Bottom line you must scan from your computer and not the scan button on the machine,
    New Friend:
I have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Posted on Dec 22, 2011
  • laurenbell89
    laurenbell89 Jan 18, 2012
    "scanner managment" was not displayed for me
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
    New Friend:
Couldn't find the scan on my computer. How do I scan my documents to my computer to save it
Posted on Mar 03, 2011
    New Friend:
If you want to simply print the item you are scanning, hit the COPY button when your document is on the scanner platen. That's all there is to it.
Posted on Dec 22, 2010
    New Friend:
I have the same problem on my MacBook. How do I go about fixing it?
Posted on Apr 23, 2015
Is airport connection not enough requirement
Posted on Oct 02, 2008
Do u get a pop up on your computer that gives you three choices click mp navigator
Posted on Mar 07, 2009
6ya staff
SOURCE:
Why Canon MX310 won't scan error 114.0. how to fix
I have this copier too but only use it as a copier in my classroom. It's a stand alone. But can't print. There is no software to install on a computer so I don't know how to fix it if there's no software.
Feb 26, 2012 | Canon PIXMA MX310 All-In-One Printer
I have a new Windows 7 PC and downloaded the MX310 software from the Canon website, but I can find the scanner software on my computer.
if the drivers were installed properly then yo can scan your documents manually by pressing scan button on machine.
you also need to install other applications alongwith drivers for other operations like scanning etc. you can download drivers/applications and manual from here
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310
plz do rate the solution if got help
Nov 16, 2010 | Canon PIXMA MX310 All-In-One Printer
My cannon mx310 wont scan photos
If you have the original CD that came with the printer, install it since the program will have the printer drivers. You didn't mention what operating system you have- I found some scanner drivers by googling "mx310 scanner drivers", and there are some out there- one site that had a free download was for a mac OS, but there are others for Windows. I have a Canon, and the way it scans is that you push scan on the printer, and it brings up the Canon Imaging Studio to receive the scan. I've never tried it without the program, but the net has drivers so I'm guessing they work, however I don't know.
You might be able to get a copy of a Canon CD from Best Buy- I know they keep copies to help people reload programs when they lose their CD.
Good luck, hope this helps, and thanks for using FixYa.
Sep 13, 2010 | Canon PIXMA MX310 All-In-One Printer
When trying to scan on my canon mx320 printer I r...
I just got done talking to Canon tech support about this issue. You have to have the MP Navigator software installed for that to work. Also, it could be that the Navigator software needs to be reinstalled because something is corrupted
May 21, 2010 | Canon PIXMA MX310 All-In-One Printer
Inconsistent ability to scan using MP Navigator EX on MX310 on Ma
I am having the same problem. Searching for a solution too. So far can't find any.
May 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 scanner driver not found
Hi there
You can download a driver from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the MX310 it for XP and Vista.
Click Link = http://www.4all2sell.com/driver/Canon-PIXMA-MX310-All-in-One-XP-Vista.exe
Ones you have downloaded just double click on it to run it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks All files on my website are only there for a limited time.
Mar 23, 2010 | Canon MX310 Office All-In-One Printer
I have mx310 copier/printer/fax/scanenr. i can copy and print but it will not scan. any suggestions?
I have a Canon Pixma MP470 and my scan control option is in the solution menu with the import option.
Try this: click start, click all programs, choose Canon utilities, choose solution menu, slide right and click on solution menu, your screen should show scan/import option, click on scan/import and chhose scan. I hope this is helpful, Good Luck.
Aug 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310
Hey,
drivers and software for your mx310 are available here
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
Select Drivers & downloads Then select windows version and Download the files you require.
Let me know if you need anything else.
Thanks,
Ekse
Mar 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
13,729 people viewed this question
Clive
Clive
old marine
old marine
Ekse
