Question about Gateway NV5468u Notebook
I have a gateway NV5422U laptop that give the message 10% available (plugged in, not charging). The laptop is not charging.
Where is the "power circuit" how do I change it?
Posted on Jul 27, 2011
  • 3 Answers
On notebooks, the "no charging problem" can be directed to some few possibilities:
1) The battery has reached it's life cycle, and need to be replaced: Every battery has a life cycle, around 600 full charges, and it loses its capability of holding energy from the recharger. So, you have to replace your battery every year or so, if you are a heavy user
2) The power supply can be defective. Either malfunctional, broken, or not supplying enough current for the battery recharging system
3) The power circuit on your laptop can be defective. If your take your battery out, and your computer can't stay on AND you are sure your power supply is OK.
So, to test either your power supply and your power circuit, take the battery out and plug it into the wire. If it works, and your battery is old, its probably the battery itself. Most computers have a "battery health checker" on the bios (when powering up your computer, press either DEL or F1 or F2 depending on your bios version)
Sincerely John
Posted on May 26, 2011
    Master:
  • Gateway Master
  • 956 Answers
How old is the unit and have you ever renewed the battery, they do eventually wearout.
Does unit run while cable switched on?
Gateway W350i won't charge new battery
1) the charger from power supply inside of the laptop is defective.some component is burn or open,or short.
2) Of course you must shure that the batteries new is o.k you must go where do you buy and test it in another computer for to see is charging.
God bless you
May 09, 2012 | Gateway Computers & Internet
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
I have a gateway P-6829H laptop p/n 1015734. My battery does not charge anymore and stuck at 2% capacity. I get the message "plugged in, not charging"
This message means that you have over used your battery. The battery will no longer hold a charge and must be replaced. I would recommend purchasing a new battery.
Mar 28, 2011 | Gateway T-6829h (5200 mAh)
Battery was low, plugged it in and now it will not turn on...gateway lT27
Give it time to charge and try again. There are power setting that may be shutting down the machine at less than 10 or 5 % charge.....
Mar 16, 2011 | Gateway LT2001u Netbook
My Gateway MD2419U laptop will not charge after it reaches 87%. It says "0% remaining" when unplugged and "0% available (plugged in, not charging)" when plugged in. Why does this...
Its an issue with the BIOS code.
Updating the BIOS will fix the issue.
Update it to Version 9A30a for Windows 7 and Version 9A10h for Windows Vista.
You can find the BIOS update on the Gateway website.
Dec 09, 2010 | Gateway Md2419u ATI 99802481742 PC Laptop
My gateway nv54 laptop battery is ok, I've checked it in lap-top tech service. But the system gives me a message "consider replacing your battery" or something like that. With a full-charged...
Unfortunately there isnt much you can do, the only real solution that has ever been known to work is to completely drain the battery (I mean keep trying to turn it on even after its died, many many times) and then put in on charge for 8hrs.
Other than that, regardless of what people say, there isnt much else you can do. And I wouldnt put too much faith in any tests these techs have run, its almost impossible to really see what state the battery cells are in.
For future reference, when you are using your laptop plugged into the mains, take the battery out, that wil help prolong its life, and never let it get too hot or charge it longer than it needs (can bend the cell walls)
Oct 30, 2010 | Gateway Computers & Internet
My laptop will not charge up, it only works when plugged in. Official message it give me is: 0% available, plugged in not charging.
If the system is in warranty, contact Dell and get a replacement Battery. If system is over a year old you most likely need to buy a new battery. If replacing the battery doesn't resolve, then it will most likely require a motherboard replacement.
May 14, 2010 | Dell Latitude E5500 Laptop
Gateway 7405 battery and charge problems
This sounds like a problem with the charging circuit on the board.
There could be a problem with the power jack:
http://www.laptopking.com/kingpartdetails.asp?ref=583&category=dcjack
They are available but will require disassembly and probably some soldering to replace.
It might be best to try another MB if you can find one cheap. Like this:
http://cgi.ebay.com/GATEWAY-7405GX-7422GX-7426GX-MOTHERBOARD-102567_W0QQitemZ200316906366QQcmdZViewItem
Mar 14, 2009 | Gateway 7405GX Notebook
Gateway Laptop
Battery poles are giving problem. Its the port connecting the battery to the laptop either has a short or just stop working. Check that & get bac @ me! Thats the problem.
KJ
Apr 24, 2008 | Computers & Internet
Gateway NV5468u Notebook Logo
219 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
