Question about Delta Model 473: Saxony Kitchen Pull-Down/Out Faucet - Venetian® Bronze
Can i remove the flow restrictor on my delta model 473
  • 4,339 Answers
Usually these are located in the aerator section of the unit.
Posted on May 26, 2011
How do i remove the caprp50 to a delta faucet 473-sssd that appears to be cross threaded?
IF CROSS THREADED YOU MAY HAVE TO USE TWO PIPE WRENCHES ONE TO HOLD FAUCET IN PLACE THE OTHER TO TRY TO UNSCREW IT MAYBE YOU COULD USE SOME WD40 OR SOME RUST REMOVEL SPAY TO GET IT LOOSE IF IT IS SO TIGHT THAT IT JUST WILL NOT BUDGE YOU MAY HAVE TO CUT IT AND BUY A WHOLE NEW FAUCET.
Feb 03, 2015 | Delta Model 473: Saxony Kitchen...
How do you fix hot water shuts off during shower with Model N-069M-OD installed December 2006?
Try flowing more hot water with your shower. During the summer you end up mixing alot of cold water and very little hot water (because your cold ground water isn't so cold in the summer). When you get close the minimum flow rate of the appliance, it will start to short cycle (fire on and off). Here's some recommended things you can do:
1) Clean the shower head - remove scale deposits and or clogging
2) Widden flow restrictor - most shower heads have a flow restrictor on the back of the showerhead; It consists of a rubber washer with a hole in the center. You can widen the hole using a drill bit.
3) remove the flow restrictor - this should be a last resort
Jul 22, 2010 | Noritz 6.3 Gallon Residential Tankless...
Flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
Apr 19, 2010 | Moen & One Handle Tub & Shower Faucet
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
After a recent water main break, our Delta Model 473 kitchen faucet now has very low water pressure. It also continues to flow for a few seconds after turning it off. I tried unscrewing the screen and...
Check the screen at the hose connection under the sink. Check the hoses for any large debris in them. Verify that the water pressure coming from the water outlets under the sink is good. There is obviously a restriction somewhere...you just need to locate it.
Sep 26, 2009 | Delta Model 473: Saxony Kitchen...
Delta 473 loose connection to sick
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Aug 08, 2009 | Delta Model 473: Saxony Kitchen...
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
Flow restrictor
Hi, all the shower heads that I replaced, the flow restrictor was always in the nut that you screw onto the pipe that comes out of the wall.it's a plastic disc, with a little hole in middle.you can use a coat hanger to pull it out.
Nov 12, 2008 | Delta & Victorian 5 Spray Showerhead
Delta Model 473: Saxony Kitchen Pull-Down/Out Faucet - Venetian® Bronze Logo
216 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
