Question about Traxxas T Maxx 3.3 Monster Truck
It will start but when the battery starter is disconnected it dies
  • jessica cox Dec 24, 2011
    We you able to figure out what the problem was, I'm having the same one...
    Problem Solver:
  • 6 Answers
Duck tape
Posted on May 26, 2011
First of all this is not my vehicle and I do not know the circumstances. The vehicle was in use when it supposedly died. Now it will not start. It has a weak batt. but even with cables hooked up it will...
first of all check the battery and starter connections for tightness and corrosion etc , disconnect the battery before checking the starter wiring connections , then try new battery if no go starter most likely needs changing , i should also advise to be thorough you should check the ignition system from switch to starter before you can positively say its the starter
Mar 23, 2015 | Cars & Trucks
Battery charging problem
Start with the alternator.
Oct 30, 2014 | Cars & Trucks
Battery dies unless positive cable is disconnected & then reconnected to start it.
Could still be your starter relay or starter itself. Turn your headlights on and then crank. Do headlights dim greatly when cranking?
Stuck starter
check alternator if its fried car will die if its good car runs with dead batteries
Jan 05, 2014 | Cars & Trucks
Drove through a wash wile raing,Truck died and was towed home.It wont start or turn over,all it does is click.The battery,starter and starter slonoide tested good.Where do I go from there?Thank you.
pull the spark plugs and see if water comes out of the cylinders. Disconnect the battery and turn it over by hand with the spark plugs removed.
Aug 23, 2012 | Cars & Trucks
Installed new baterry and new alternator...battery or alternator dies in one day
the alternator will not die in one day unless there is a direct short causing diode or coil winding failure which would give signs of smell, melted wires. Disconnect battery and give full charge. what year is this? while vehicle is running you should be able to briefly disconnect positive battery post connection and vehicle will still run if alternator is good. For a new battery to die in one day, one of two things i think has happened. Either the batt is faulty from supplier,( not likely but i have seen it ) or there is a direct draw or grounding taking place whether its direct in the starter selonoid or a direct draw through accessories. Are you sure all switches are off ? Push switches (on interior lights) nothing like dome lights,delayed lights are staying on! Does vehicle start hard like it almost needs a jump. If it has to be (and it takes time). to find out what is drawing the power ( i am old school) disconnect positive power source on batt. 2) disconnect ignition power source on starter. 3) connect pos batt wire to starter, 4) touch positive cable to positive batt post and look for spark or contact. if this reacts then selonoid or starter motor is shorted drawing the current. Or if you have volt meter and know how to use it, this is good to. If checks good then hook ignition connection back on starter.(disconnect pos terminal on batt prior to re-connect) I think the battery is having the life sucked out of it by a short in the system ( A DRAW ) this could be a quick find or fix or this could take days to track down. alot of variables here to try to explain. but i would seek into the starter first as usually this drains the battery quickly .
Jan 13, 2011 | GMC K1500 Cars & Trucks
When I turn the key everything works but the starter which doesn't seem to be getting any juice
Hi
Make sure the terminals on the battery post are clean. Use water and a little baking soda to neutralize acid. Disconnect battery first! Check for corrosion at the starter itself. If starter clicks when you try to start it then this is my guess. However, a dying battery can run everything fine but a starter needs alot of energy. Could be also a broken wire, poor ground, or starter solenoid. Good Luck!
Jul 10, 2010 | 1995 Chevrolet S-10 CA Edition
Every time i install a starter the battery light comes on and the car dies. I have a 2000 Grand AM with a 3400 engine, should the car still run if i disconnect the battery, if it doesn't that means a bad...
Everytime you replace the starter? how many starters have you replaced? Why are you replacing starters? May be you need to start buying quality parts. The Starter has nothing to do with the battery light. DO NOT DISCONNECT THE BATTERY WHILE THE ENGINE IS RUNNING. That can whipe out the engine computer.
Dec 15, 2009 | 2003 Oldsmobile Alero
Truck will not start
did you disconnect the battery at all? this usually resets the immobiliser so you'll need to reset the immobiliser with the key fob, other wise it could be your starter motors become disconnected or died
Jun 06, 2009 | 1993 Ford F150 SuperCab
Car just died after putting new starter
When you put the new starter in, you didn't put one of the cables back on the post. It probably grounded itself enough to start and run, then moved by vibration, or a pothole, or gravity, and killed the motor. As for the arcing battery.... are you sure you didn't attach the jumper cables to the wrong posts?
Jan 05, 2009 | 1997 Nissan Pickup
Traxxas T Maxx 3.3 Monster Truck Logo
44 people viewed this question
Top Traxxas Toys Experts
cwradio73
Mike Darragh
Level 1 Expert
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
