Question about Rinnai Digital Remote Water Heater Control Mcc-45-4us
I have a Rinnai Model 2532 with an MC-45-4US and BC-45-4US control units. I finished another bathroom and want to add a controller, but have been told that a compatible BSC-45-4US is no longer made. Is there a newer controller model that will work with the older control units? Rinnai customer supoport was no help at all!@! Thanks, Ken
    Novelist:
  • 120 Answers
Sorry Ken I worked for Rinnai Australia as a service manager so treat my advice with a little cuation but you should find the basic universal controller should work fine. The code over here is a MC-91 Q2A. It will MC-91 sometihing for over there (I'm guessing from the codes you use you are across the pacific!). You can wire this unit either back to the heater or to wiring from another controller, just match the colours and link them in. Power off the heater first but it is all low voltage.
Posted on Jun 06, 2011
  • Beaubeau01 Jul 20, 2011
    Ken-- I have two of them brand new in the box--we built our house and ended up with four of them by mistake. Are you still interested?
I have a wall mounted tankless water heater for
It's scaled
Do you have a softener? Water must be 15 GRS/PPM or less in iron and calcium. Hot spots in unit are boiling water and are causing the noises.
Descale and flush unit following Rinnai Specs and check water hardness for compliance with Rinnai standards because too hard an inlet water will VOID the Heat Exchanger Warranty (10 year).
Oct 19, 2014 | Water Heaters
Rinnai 2532 error code 10
Error Code 10 Problem: Reduced or no air supply to the water heater or there is an obstruction in extracting the flue gases out.
Solution: Make sure that the recommended Rinnai venting is used, there is no obstruction in the venting system, no reduction in diameter and lengths are per instructions. Also make sure that nothing blocks the venting system or fan, and that dip switch and condensation collar are set properly.
Good luck,
Marty
Jan 20, 2013 | Rinnai Water Heaters
Where can I purchase one of these (mcc-45-4us)controllers from? It is for a Rinnai tankless heater. Thanks
I found 1 on eby with a slightly different model prefix BC-45-4US
but it should do the same job! heres the item number 280639936016 so you can search for it on ebay
Mar 09, 2011 | Rinnai Digital Remote Water Heater Control...
I have a Rinnai MC-45 US. One morning, we had no hot water & the temp on the control panel read 12. So I pushed the Priority button. We now have hot water, but the priority button is still lit. It has...
Error code 12 can sometimes be caused by a short circuit on the low voltage side of the installation. Could possibly be a fault with the controller itself which is low voltage.
Jan 31, 2011 | Rinnai Digital Remote Water Heater Control...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
How to install rinnai 2532 Continuum Individual temperature control
if you mean additional remotes then go to rinnai.com and enter your model number. go to owners manual and it gives step by step instructions
Jan 10, 2010 | Rinnai Webstone The isolator EXP tankless...
Need to wire a zone control for a closed system with a circulator
thats because the rinnai does not have a set up for a circulating pump it would make the unit run all the time,, they are not designed to work that way,, you will have to just wait for the hot water to get to the faucet just like before,,don't let any one tell you there is a way once the water flows it turn on the tankless so it would never shut off, you could get on that goes on a timer on say the farthest fauset away from the unit and set the timer to come on like 2 min before you are ready to use the water in that bathroom in the morning or at night other then that there is nothing else you can do
Jan 28, 2009 | Rinnai Digital Remote Water Heater Control...
Rinnai Digital Remote Water Heater Control Mcc-45-4us Logo
737 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
