Question about Garden
I ran over the corner of the diamond plate that covers the electrical stuff in the ground when I was mowing the other day. Now whenever I start the mower it shakes really bad and the backyard has about 3 ft. high grass that I really need to get rid of. Help me...what do I do to fix this problem. Keep in mind when responding that I am a 26 yr old girl who has no problem doing anything a guy can but I may need you to give me details. Thank you.
    Problem Solver:
  • 6 Answers
Change the shear pin
Posted on May 26, 2011
It ran mowed a hard lawn of grass now it wont start to moe soft blade grass
while unplugged try turning the blade by hand . it should turn easily . then check to see if grass or string has gotten wound around the shaft.
Oct 17, 2015 | Greenworks 20" 12 Amp 3-in-1 Electric...
Oil coming out of air filter
Look for a crankcase ventilation tube or such, It may be covered with grass dust and stuff, is probably a sponge to keep dust out of the motor. Rinse it out, and make sure the airway is clear.
Nov 24, 2013 | Garden
1986 chevy sprint not getting spark
check fuses and clean your wiring its old as DIRT check the ground and make sure they are tight
Jul 25, 2013 | 1986 Chevrolet Sprint
How do I replace the corner lens cover
To replace the cover plate on an electrical outlet, simply unscrew the screw from the plate, remove the plate, then replace with new cover and screw in. You can get new cover plates at Walmart or Home Depot. Most come with 1 screw, but some have 2.----------------------------------------------------------------------------------------
opcom 2010
Jan 04, 2013 | 1995 Toyota Corolla
Push start button and get a buzzing kind of sound.tail light is also dim
I could have sworn I answered this question the other day. It sounds like you have a bad battery. Remove the battery and take it to an automotive parts store. Ask them if they would load test the battery for you. Usually when a battery has good connections and does this, it's either badly discharged or a cell is shorting internally resulting in a battery of less than 12 volts. Depending on which cell shorts, the battery voltage could drop as low as six volts.
If the battery checks good, make sure all your connections are good at the battery and starter. Look under the "electrical panel cover" just to the rear of the coil cover and find the starter relay. Turn the ignition switch on and press the start button while holding this relay. It should click once whenever you press the button.
If it does this, look at the end of the starter from the right side of the bike. The end plate of the solenoid is shaped like a pentagon. At the top of this plate, there is a single wire connection. Unplug this wire and connect the red lead of a Digital Volt Ohm meter to the wire. Ground the black lead of the meter and put the meter's function switch in the DC volts, 20 volt range. Turn on the ignition switch and press the start button. You should read battery voltage. If so, your starter is bad.
Good luck
Steve
Aug 23, 2010 | 2003 Harley Davidson FXD Dyna Super Glide
Cub cadet RZT 42 shuts down after about 30 min of mowing.
Check your magneto. I have had them cease to function whenever they would get hot. When cooled down, they would work.
Jul 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Loud bang, hole in motor
Sounds like you threw a rod. If your warranty just ran out you might be able to get sears to still honor it.
Jul 14, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mits diamond vision 65
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Dec 26, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
