Question about Lands Phones
Nokia 6500 classic charger not working
I have recently had my phone unblocked but when i plug in the charger the screens comes up with "Charger not supported" and doesn't charge, even though it is the nokia charger i got with the phone.
Can you help me with this problem please?
Rhyno
  • Anonymous Apr 03, 2009
    I got that exact same problem with my 6500 classic too... it really bugs me becouse besides that MAJOR problem, I loved that phone... it's always too good to be true with everything
  • 105 Answers
Just try with any other same type of charger
Posted on Aug 16, 2008
IHAVE ANOKI 6500S WHICH HAS NO CHARGING CAN ANY ONE HELP ME
Posted on Oct 28, 2009
I need an unlocking code
You can get the Unlock code for Nokia 6500 Classic Model Phone from the site Unlocking4u.com/nokia/rs6wp8/ and Unlock it from Network Lock.
Dec 28, 2011 | Nokia 6500c Classic Professional Blue LED...
Nokia 6500 wont charge
Where you connect your charger there is a loose connection there,what i can tell you for your phone to stay alive is just buy an universal charger it is not expensive,you put your battery in then after charging replace it in your phone and the problem is solve .
Feb 09, 2010 | Nokia 6500 Classic Cellular Phone
Nokia 6500, got wet (damp) now the phone wont recognise the charger nor the usb cable, can you help solve this problem please everything else works fine.
firstly dry ur mobile via light heat or dryer
now with the help of toothbrush & petrol clen the charging port area & usb port areas
i m sure it will work
Jan 17, 2010 | Nokia 6500 Classic Cellular Phone
Nokia 6500 classic - no sound since replacing screen
This can be a problem for guys repairing this prob on this model themselves. I have repaired this problem several times before by replacing the unit that holds the screen in place. This is the part metal part that has 5 screws in it. once you take the screw out and lift this piece out you will see that there is also a bit of flex attached to it. This flex includes the charging block and also the connections that the speaker is in contact with. First before replacing this part make sure that it is fully connected onto the board and that it isnt just loose. The flex where it connects to the board is doubled over and glued back to back. peeling this apart will help you fit it easier. once LCD and this part is in try plugging the charge in and see what happens. If i is still broken you probably need to replace that bit of flex.
May 27, 2009 | Nokia 6500 Classic Cellular Phone
NOKIA 5310 can't turn on
Did you replace battery recently? Sounds like it has bad or wrong battery. If not, it is just dead.
To fix:
Power up phone on charger
While it is ON, pull the battery
Leave out for 1/2 to 3hr - phone still plugged in
Replace Battery, phone will power cycle and start charging
Leave plugged into charger 10-14hrs
Should be good now
Mar 26, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 classic charging problems
I have had exactly the same problem, and have replaced both the charger and the battery.
I think the problem lies in the contacts between the charger and the bayonet and the battery..
Soooo
I put a couple of peices of folded paper behind the battery, making a very very snug fit.
then, (this is a bit fiddly)
i carefully folded a slim peice of paper to wedge behind the charger pin and the back of the bayonet, so the pin is pushing against the front of the bayonet.
( to do this, position the paper over the pin and push into the socket at the same time.)
works like a treat :)
if you had exactly the same problem, it will be due to the charger wobbling around about the socket.
this ensures a tight fit and means it maintains contact all the time.
good luck, and i hope you haven't started to tear your hair out quite yet.
Nov 12, 2008 | Lands Phones
Lands Phones Logo
996 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
