Pixma 150 Canon printer jams paper with one sheet or a full load of paper,...any suggestions?
    Scholar:
  • 118 Answers
This depends on where the paper jams. Does it pickup the paper and move it at all?
If it does,nt then your paper pickup roller needs a clean.
If it moves it a small way and then jams before the paper gets through the feed rollers then usually something is jammed in the printer that is obstructing the paper from feeding. It may be a small piece of paper or many other things as I have found, pencils, paper clips, coins, all sorts of things in printers.
Posted on May 26, 2011
Paper jammed under roller small piece of paper keep saying jam e3
Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
Procedure:
1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
2. press [maintenance] repeatedly until <b> appears.
3. press [black] or [color].
4. repeat steps 2 to 3 twice.
5. open the paper output tray.
6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
7. repeat steps 2 to 3 times.
the sheet paper is automatically fed in and then out of the machine.
have a nice day.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Under one year old pixma mp150 all in one/ changed ink cartridges/error code E2 / saying no paper ????
I have had a MP 150 Cannon Printer with a E3 paper jam code..when NO visable paper jam is present ! Your No paper problem may be as a result of similar issue due to a small piece of paper stuck in the roller assembly out of sight. TRY this, Turn printer off wait (10 seconds) or more then turn printer back ON and listen for roller assembly to turn the ROLLERS and then FORCE FEED
a sheet of paper into rollers until it PULLS paper through and SEE if any scrap of paper comes out with the sheet !! If this works you should see that it clears the code. and resets your printer.
Let me know if this works. Phil at palcando@yahoo.com
GOOD LUCK !
May 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer feeds in 2 or 3 sheets of paper at a time and then jams
Dears eveenz,
It seems that paper feed roller of your printer is broken. This part is integrated in drive assy. You need to replace drive assy of the printer in order to feed the paper properly. I plan to discuss this topic at Inkjet Printer Forum since I cannot post image more than 150 kb here. Explanation with image will make you know more easily. Please send me your mail to ijxpert@gmail.com so I can contact you as soon as I finish my post there.
Please rate me when you find this answer be useful for you
Regards,
Nov 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pIXMA mp 150
This is definitely a mechanical problem. You might want to at least partially take the printer appart and inspect it very thoroughly if you haven't done so yet. Did you have any paper jams before? Sometimes when you remove a paper jam the sheet rips and you end up with some shreds of paper lodged in the printer mechanism causing more jams. Another possibility might be cracked or bent paper guides, or simply dirty rollers (these you can clean with alcohol).
Aug 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
50 people viewed this question
jasbo
jasbo
