Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
From day 1, the HP 8500 printer will print the last page first on any number sequenced items (paychecks) or any multiple prints. Using Quickbooks, it tells how to change but is faulty in the explanation. There is no changing print order in the printer options. Any fix will be welcome. Thanks
  • HP Master
  • 4,350 Answers
Look for Collate under printer properties just before you print. this switch changes the print order.
Posted on May 26, 2011
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
HP Officejet Pro 8500 Printer does not print the last line
Try uninstalling the driver and reinstalling it by going to HP's web page. Before doing so, defragment your C drive.
Oct 22, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
Is parially printing last line of a check address
Well what people dont understand is that drivers operate the hardware. What im saying to ya is unless you want all the extra bells and whistle it should work
Did you print a test page and does it meet your demands >? I myself have to regedit my systme and redue my printer
Oct 20, 2009 | HP Photosmart C7280 Printer
Hp 8500 officejet won't print PDF files; word, quickbooks all work fine.
You need to go into Printers/Properties/Advanced
Select checkbok Spool Print Documents. Then it will work.
Sep 17, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Print job disappears withouth printing in Quickbooks
Go to the printers folder, right click the printer and chose properties. Under properties go to the advanced tab and check off print directly to this printer. I work with HP and find this solves the problem of printer 95% of the time
Jun 19, 2009 | Office Equipment & Supplies
By Pass tray printing
I had this problem when printing checks in Quickbooks, I resolved the problem by going to File, Printer Set up, then select checks/paychecks, then select Options next to printer drop down box, then select Paper tab, Input tray select "Bypass Tray"
Not sure if this is your application, but it did resolve my issue.
Nov 13, 2006 | Ricoh Aficio CL3500N Laser Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
