Question about Fuji FinePix S3 Pro Digital Camera
After i make a shot, I get "REC" blinking on the
philipp
  • 217 Answers
SOURCE: Fuji s2pro (2 units)
Your shutter mechanism reached its life expectancy, (5000 shots).
Posted on Aug 24, 2007
clickman
  • 93 Answers
SOURCE: Is there a remote shutter
To be honest, that is one thing missing from the Camera. There is no remote shutter release controls....
I did find a website with a guy asking the same questions and the sent him a link to a guy who made a system for it.
This is the forum link
http://photography-on-the.net/forum/showthread.php?t=428837
and this is the link to the creation
http://www.breezesys.com/MultiCamera/psr_index.htm
Posted on Dec 02, 2008
SOURCE: Fujifilm F470: camera opens, shutter opens but no image!!!
I had the same problem with this particular camera. Here is the necessary steps to fix your problem.
1. Take out the battery because you dont want to short anything when you're inside it.
2. Free yourself of any static.
3. Remove six screws on the outside of the camera. Note that two of the screws in the botton are not phillips head. If you have a very small flat-head screw driver that will work.
4. Pull the camera apart very carefully. Unplug the little wiring harness by pulling up the little black clip that holds it in its seat.
5. Carefully remove the LCD screen. You dont have to remove any screws here. Just carefully pull it out. There is a peice of double sided tape that holds it in in place so you will fell some resistance.
6. Remove the two screws behind the screen that holds the lcd holder in place. Theres also one or two in the left side of that.
7. Plug back in the lens wiring harness. This is where your problem was. It came unplug from probably being dropped.
8. Repeat the steps 6,5,4,3,2, and 1 to put it back together.
Hope that this fixes your problem. It fixed my camera.
Posted on Dec 29, 2008
  • 7 Answers
SOURCE: shutter release cable for panasonic fz18
There is no cable release for this camera--the belief seemed to be that the timer function would be sufficient
Posted on Apr 26, 2009
zohail
  • 1223 Answers
SOURCE: HI All of a sudden, there
BUT NOW U HAVE FOUND SOLUTION
CCD FAILURE !
but u will get it repaired Free of Charge as Fuji has taken notice as all manufac and i got my S5000 repaired Free from Fuji just call them tell them about BAD CCD it is a known manufac fault in thousands of cameras just call them quick
www.fujifilm.com
see this thousands suffer from this
http://www.imaging-resource.com/badccds.html
Posted on May 08, 2009
Have solid red light at the 7 o'clock and blinking red light at 11 o'clock
[PDF]Download XD1080 User Guide - Replay XD
www.replayxd.com/downloads/.../Replay-XD1080_User_Manual-EN.pd...
Note: The red LED on the rear will blink when the memory card is not inserted .... The Start REC button should always point up or at the 12 o'clock position for a ...
LG TV Blinking - YouTube
? 0:43
https://www.youtube.com/watch?v=Q8JG53DU6Rk
Nov 5, 2015 - Uploaded by Gillet Gaming
My TV suddenly started blinking when I turned it on at 12o'clock. ... I was going to use it when a few ...Missing: p
Diamond - ndxLocOut
www.nuforc.org/webreports/ndxsdiamond.html
11/7/15 18:05, San Diego, CA, Diamond, 5 minutes, Orange Diamond like .... 8/23/15 21:08, Wildwood Crest, NJ, Diamond, 2 minutes, Hovering red light, ... Diamond shaped brilliant white light with red light in eastern sky at 12 o'clock ..... flashing blue yellow the red at times staying solid red or blue seems to get bigger. 2/27/ ...Missing: p
[PDF]Air-Pak 75i SCBA - User Manual - Scott Safety
Dec 21, 2015 | Televison & Video
How many times do I press the button to get video recorder on
one time is enough for recording, a delay of min 1sec to 4sec will happens to dispaly the rec indication.
Apr 13, 2015 | Video Cameras
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
The dispaly blink "Sud" and
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Sep 05, 2011 | Washing Machines
I get the "Digital noise
Try this method :
1. Menu, select setup
2. Plug and Play
3. Enter pass code by entering 4 digit number (0-0-0-0)
4. Select language
5. Switch to Home Use
6. Follow the instructions.
Good luck.
Mar 07, 2011 | Samsung LE40R74BDX 40 in. LCD Television
My fax machine is blinking "printer error", i cant rec. any faxes....URGENT
A printer error has occurred. Open the printer
compartment cover, make sure the print cartridge is
installed correctly, and then close the cover.
Dec 15, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Fixing Pioneer PDR-555RW
Receaving display blinks (check disk) sometimes cd will read but after about one minut the cd eather stops or skips. I tryed to clean the cd player with T'nB cleaning cd but did not solve the problem. Can you help me?
May 08, 2008 | Audio Players & Recorders
Fuji FinePix S3 Pro Digital Camera Logo
37 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
