Question about Foxconn K8M890M2MA-RS2H Motherboard
Hello experts i have plugged in all the power and my ram and graphic card but it wont show screen and cant find any signal to the computer. What should i do ?
  • 386 Answers
What kind of power supply are you using? Is the enough for your MB?
Posted on May 26, 2011
Packardbell imedia
Hi paul,
1. check signal cable from pc into monitor and try to use other signal cable also do try into other monitor if prob cant solve.
2. your imedia include with graphic card? If has a graphic card try use other good graphic card to test the display run or not. If cannot.
3. Try make some cleaning into your ram, Test your ram one by one because sometime no display appear because of broken ram.
Try check this 2 site to other solutions..
Thanks..
1. How To Test Computer Monitor That Won Display Or Is Not Working
2. Fix Your Computer Monitor When the light is yellow or amber not green (try this one)
Good Luck.
Jan 19, 2014 | AMD Computers & Internet
Flashing green light on graphics card and power wont turn on
a green light ain't nothing wrong with, red it probs with the card.
So in fact this has noting to do with your graphic card.... It's your motherboard.
Can you remove your graphic card and plug your screen in the onboard plug,. I forgot to tell to turn off power , before you begin. So not only turn off the powerswitch, then there's still current, pull out the powerplug, remove your asuscard and plug in a manual pcboard and manual mouse. If done, tell me what happens when you boot, nothing. are you able to use bios????
Nov 12, 2012 | ASUS Directcu Ii Top Geforce Gtx 560 Ti...
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
A7600 GS TDH, Supplemental power supply problems, every time i load a game it also dosnt show the true graphics it shows some of it distorted, sometimes when i turn off my computer an restart it, i go to...
Hello there,
In Windows, it just comes up with a message saying it will be clocked down, so you just click "OK"? if molex is not plugged.
1. You should install the driver for the graphic card so it wont show distorted images, Microsoft display drivers are not reliable in gaming you may experience distortions.
2. Plug the molex or 4pin power to your card and observe if you will encounter the same problem after doing step 1.
3. If not try to test another PSU or acquire a new PSU that is powerful enough to run the card - not using the power cable could damage all your system.
Hopefully this information helps.
Happy Gaming
Thank you for using FixYa.
Aug 10, 2011 | Leadtek WinFast A7600 GS TDH GeForce®...
I have a acer m 1620. when i power it up the screen comes on and say no signal and then goes black. the fan comes on and continues to run but thats it. does anyone have any ideas?
It sounds like the video cable is loose, try unplugging it and plugging it back in. Also check if the screws on the video cable are tightened. If this does not work the graphics card has likely failed.
Mar 05, 2011 | Computers & Internet
Hi mine wont show screen at all! i reset ram no help. i turn it on no screen n after about 20 secs it has one long beep?? i cant tell if its loading or not!
the long beep indicates faulty ram oir graphics card, i would say ram, you also need to reset the bios, via the cmos jumper or battery, continuous long beep is a dram error, so the ram is faulty, get some new ram and make sure its specs match the computer
Feb 14, 2011 | Gigabyte GA-945P-S3 Motherboard
I bought a computer with windows xp professional everything works including graphics card but my monitor is not showing anything the light on the front turns green when computer boots but thats it nothing...
try to plug properly the vga adapter,or if you have graphics attached(not the on board you are using)go to bios settings and adjust the graphics adapter you want to use..or if the graphics card you are using has a cd,place it to cd rom and install the driver for the graphics card...
Feb 12, 2011 | Computers & Internet
Blank monitor screen
It appears that this motherboard has an on-board video port, I would recommend unplugging the video card and try using the on-board video. Make sure that when you do this, the BIOS POST screen shows, if it stops making the beeps, but still doesn't show anything, you might want to reset the BIOS (using the on-board jumper, sometimes also displayed as CMOS reset or password reset). If it still beeps, it might be the RAM, and you might want to see (if you have more than one stick of RAM) if you can try unplugging one or the other, or even switch their locations. Good Luck.
Mar 25, 2009 | ASUS Computers & Internet
No signal on monitor when card is seated
the problem occured probably because of a power shortage of motherboard battery malfunction, if your motherboard has an integrated graphics card you then need to enter setup and disable it or choose which graphis card your pc has to use but you have to do this while connected to the on-board vga slot as the other one won't be working, you will problably find the choice under the
'integrated periferals" menu in the setup menu, and to access it you have to press the "DEL" button when your pc starts-F10 in some devices-
Nov 29, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
Foxconn K8M890M2MA-RS2H Motherboard Logo
95 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
