Question about Vacuums
Dehumidifier model ddr503h-3 error code 3 - Vacuums
I just purchased a used portable air conditioner, a danby dpac120068. It is not producing any water when in dehumidify mode. Also, it seems as though the air conditioner is on even when in dehumidify...
The A/C will be on when dehumidifying... that's how it does that...
If it is not collecting water, it is probably because the humidity is too low in the house already...
I would give it more time....
heatman101
May 25, 2011 | Vacuums
My dehumidifier shuts off within a few minutes of turning on. There is humidity in the air but it is not collecting any water in the bucket. I feel air being sucked in the front and blown out the back. I...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 21, 2011 | Vacuums
Should my dehumidifier be blowing air out? It is also not collecting water?
heatman101
Apr 17, 2011 | Maytag Vacuums
Dehumidifier fan appears to be working, but no water is being collected in the vessel. 'Clicking' noise when in operation
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 12, 2011 | Vacuums
Have dehumidifier 1yr old what is standard warranty on this product
Standard warranty is determined by the manufacturer and you have not stated what model or make of dehumidifier you have.
Most appliances are covered by 1 year, some by more. If you purchase refurbished, remanufactured or reconditioned units, you could get a 30day, 3 month etc. and this differs between retailers.
Your warranty is honoured by the retailer and not the manufacturer so you could contact them to see.
Feb 06, 2011 | Vacuums
We have a zenith dehumidifier model ZD300 & the bucket full light keeps flashing. the percentage number wont go higher than 1%. we have turned it off/on & unplugged it. When we do this it will...
I've had the same issue with mine. I am a 12 year refrigeration tech. I checked the float switch which would normally cause that indication light. However manually pushing the switch and then checking it with an electric meter that was not the case. I think that is instead, an error code set by the manufacturer to assist the service tech when or if this failure occurs during the warrenty period. I also checked the next possible failure in the sequence of opperation which would be the compressor overload relay. That is sometimes why, as some people have posted, that after when unplugging the unit, it operates for a short time then again fails. In my case that was the failure. If that would have not been it than I would have tried the compressor start relay. I purchased the overload relay from my local HVAC/plumbing supply for around 7$. The control can easily be replaced by any handy homeowner. Also, as a service tech, 7$ and two wire nuts is better than a 145+$ service call.
Nov 28, 2010 | Vacuums
Our dehumidifier(Simplicity Model 43-54006 ) all of a sudden has stopped pulling water out of the air. It runs but it does nothing. Any suggestions? Thank you.
heatman101
Sep 02, 2010 | Vacuums
My roomba 550 is having an error code 3. I change the power supply and the problem still. I will appreciate your answer
Your error code is a charging fault code
By clicking ojn the link below is a chart of fault codes. Save this useful chart for further use later
http://www.robotreviews.com/wiki/troubleshooting-roomba-5xx
Apr 11, 2010 | iRobot Roomba 550 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
