Question about Amana Ovens
Why does the code F5E2 show up when i;m trying to use my self clean on my amana stove?
SOURCE: Frigidaire self clean electric stove 'f9' message
looking for lower element for Frigidaire ElectriClean Wall over
Posted on Nov 21, 2009
geemarie
  • 876 Answers
SOURCE: Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Posted on Aug 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: amana self cleaning gas oven and the code f-4
Replace the oven temperature sensor. It is shorted.
Posted on Jun 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: When I turn on the self cleaning cycle on my range
F5-E2 Door Switch Check Switch
Posted on Jun 20, 2010
  • 11800 Answers
SOURCE: I have an Amana gas
The defect is in the controller board and you can't do anything to fix it, you don't have access to replacement parts.
The only authorised repair shop in Puerto Rico is called Bonilla Refrigeration and can be found in Ponce, Calle La Guadalupe 1931 URB.
Phone number - (787)843-6004
Posted on Oct 01, 2010
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
My Amana self cleaning oven quit working and display but stove top still works
pull the oven part out and check the connections on top of the oven where all the controls are ,bet it has a burnt or corroded connection here between the supply for the top and the oven
Apr 20, 2012 | Amana Ovens
Model# AC53350AF Stove locked up at cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker
Dec 26, 2010 | Amana Ovens
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Stove door locked and continues to beep and flash code F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Ovens Logo
479 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
