Question about Whirlpool Dryers
David@chirpyMy wife has knocked the knob off our whirlpool awz 8578 dryer. Is there an easy way of mending it?
    Brigadier General:
  • 3,301 Answers
You can get those knobs at http://www.searspartsdirect.com
Posted on May 26, 2011
  • 55 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
http://www.whirlpool.co.uk/ifudocs/501930700361GB.pdf
Posted on Mar 25, 2008
SOURCE: Whirlpool AWZ 650 condenser dryer
MY FILTER LIGHT IS ONN ALL THE TIME, HOW DO I CLEAN THE FILTER...WHERE IS IT, IS IT THE ONE BELOW THE FRONT DOOR THAT PULLS UP AS IN THAT CASE I'VE CLEANED THAT?
Posted on Aug 27, 2009
rogrrabbit
  • 986 Answers
SOURCE: Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Sep 12, 2009
SOURCE: have to replace broken belt on a whirlpool awz
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Posted on Sep 30, 2010
SOURCE: whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Posted on Jan 01, 2011
Whirlpool dryer AWZ 8578, power is going into the
2 things stops your drum from turning ist thing to check is belt broken you take the top off and look into and you will be able to see if iis broken if that is ok then you will have to check the compasitor it on the side it like a big fuse
Oct 13, 2014 | Dryers
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
Whirlpool AWZ 8578 - does not stop, always needs manual switch off
These symptoms most usually are a bad timer/control. If the dial turns all by itself, and continues to turn by itself like a clock does, it is likely a timer/control must be replaced. Same results if it will not advance by itself either.
You could type in "Sears Parts" for the new part, typing in your complete model number. If you wished to try a used control, after obtaining a part number, you could type that in to "e-bay" and see what you find in new or used parts there. I do.
Be blessed.
Feb 15, 2014 | Whirlpool Dryers
AWZ 7913 Still working but making a very loud noise, what can I do?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 01, 2011 | Whirlpool Dryers
I got a Whirlpool AW Z 865 dryer. It is a condenser dryer and the water is not going up to the collecting bucket, but remains below and then leaks out and floods the floor when I open the little pull door...
I had a similar problem with a Whirlpool AWZ 8578 Tumble Dryer. The solution was to clean the fluff out of the rubber grommet in the drain hole under the left front of the condenser. Then the water from the condenser could run into the collection container underneath.
Nov 25, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
Jan 09, 2010 | Whirlpool Dryers
Door latch broken on my Whirlpool AWZ 650 dryer
it is very easy to replace you just have to lift the top to press the clip and push it out please rate
Jan 03, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
