Question about Whirlpool GC3NHAXVY Stainless Steel Side by Side Refrigerator
My fridge seems to work fine but my freezer goes through cycles where it gets way too cold (-12) when its set at 0F. The ice maker was just cleaned out and dried thoroughly. 3 days later it is full of ice but the ice in the bottom of the compartment is stuck together and frost builds up. Any ideas on what the problem is? I have a repair man coming out today but I want other opinions before I spend too much money. Your help would be greatly appreciated!
fridgetech
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
watugot
  • 290 Answers
SOURCE: Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Posted on Nov 18, 2007
roadbird383
  • 40 Answers
SOURCE: Whirlpool Freezer not freezing at all
The evaporator is located behind the back wall of the freezer.If the fridge part is ok,you may want to check the dial settings.If they are ok,then check the air flow into the freezer,you may have something blocking it.If that checks out ok,you may have a bad defrost timer.You can put it in defrost manually and see if this improves the freezer.
Posted on Dec 05, 2007
  • 1314 Answers
SOURCE: frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Posted on Dec 31, 2007
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
Ge Gsh25jsxnss side x side fridge is not getting cold, took plate off & damper works fine, I don't see ne kind of fan, it goes straight 2 the freezer near the ice maker. freezer is cold & working fine
Evaporator fan motor has probably failed. p/n WR60X10185
It is located in the freezer section, behind the back panels inside, and under the icemaker. Remove the screws on the bottom panel in the freezer, remove the ice maker, auger motor, and panel. is is about center of the freezer.
Jun 22, 2016 | GE Refrigerators
JCD-23 making too little ice
Check the water flow to the ice maker. Turn the supply water off, loosen a fitting near the ice maker and then turn the water on. You should get plenty of water. If it is slow, check the filter.
Dec 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
Maytag Fridge MFI2568AES - Ice maker not filling
Check water line going to fridge and ice maker! Does water come out ok?
Jun 17, 2012 | Maytag Refrigerators
I have a Matag Refrigerator Model MTB2156DEW. The freezer is located on the top of the fresh food compartment. For approximately a week the refrigerator has been constantly running without cycling. ...
Defrost the unit. The fridge section cannot cool if the freezer is iced over since the fridge gets its cold from the freezer. If you don't have a second fridge use a hair dryer to speed the defrost.
Apr 06, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Hi, I have a fisher and paykel fridge for almost 3 years.The problem is that the ice cube maker stop working. I have check all the things that are mention in the fridge guide, water supply is fine, the ice...
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
Jan 29, 2011 | Fisher and Paykel Active Smart E522B...
Fridge not pumping any cold
All your cold air for the fridges comes from your freezer compartment.If you are haveing ice build up in the freezer comparment there may be an issue with your defrost circuit.
While the unit is in a cooling mode open the freezer door and listen to for the fan running in the freezer this is the evaporator fan that circulates the cold air to your fridge compartment if it is not running replace it.
If it does run try and check your defrost circuit and make sure the unit goes into the defrosat cycle
May 19, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
New used refrigerator
HI thanks for your question. a fridge takes at least 24 hrs to get cold and cycle give it some time. the gurgling is normal its the freon boiling in the freezer. its normal. thanks the appliance doc. please rate my answer. thanks.
Jun 19, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool GC3NHAXVY Stainless Steel Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
