Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
Line fails to cut off on your cordless 18 volt trimmer/edger (NST2018) According to the instruction book I need a new blade. According to this website there is "no estimated release date" for the blade which would cost 81 cents if I could get it. We once had a service center here which informed me they no longer service these. (Just these or all Black & Decker? I don't know) ??????????
  • S Allen May 20, 2013
    Having the same problem. The blade isn't sharp enough to trim the line. Isn't this a problem for everybody who owns one of these?
  • 3 Answers
Quit buying blackand decker units .if they wont supply small parts they are not worth dealing with
Posted on Jul 12, 2012
    President:
  • Black & Decker Master
  • 1,545 Answers
The service centers have stated in unison that it is no longer "cost effective " for them to repair these. They claim they are a "disposable" item and should be replaced once worn out. This may surprise you, but I suggest that you remove (if you have to drill it out then fine) the blade and attempt to sharpen it some. Or leave it off and replace it with a large cutting razor type blade used for shears etc. They do make sharp blades large enough to do the job. You just have to find them.
Posted on May 26, 2011
  • Roy Cagle
    Roy Cagle May 26, 2011
    A very small triangular shaped file can be used to "touch up" the edge on the cutting blade.
  • Roy Cagle
    See part #22 of The following parts list. You can purchase it too.
    http://servicenet.blackanddecker.com/Pro...
My grass hogger line extending unnecessarily and never get line short ( i meant extra line never get cut off. I think i have two problems here Why line is extending unnecessarily? & why it's...
If you look closely inside the shield, at what would be the leading edge as the string approaches, you should find a little cutter that trims the line if it is too long. This can get dull. I have had to sharpen the one on my B&D with a file before.
Sep 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
Line doesn,t feed automaticly
The line may be on backwards or has developed a knot. Debris may have worked its way inside the bump head preventing it from functioning.
Check out these items.
Best regards
Mike
Aug 20, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
My line on my grasshop keeps getting longer and longer....it doesn't cut as used. How come?
There should be a metal knife attached to the inside of the guard housing. This knife will keep the string at a length that keeps it within the housing. It is either screwed or snapped in place. If present, clean the debri away from it so it can cut the line as it should.
Apr 03, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Line will not advance line is not crossed in spool
Rewind the line and make sure you wind in the direction of the arrow on the spool. Not an unusual situation.
Mar 31, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
214 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
