Question about Garden
Pony lawn mower wont start replaced spark plug and fuel filter now probably need to get to carbuerator. dont know how to disconnect ti
    Scholar:
  • 147 Answers
Alot of times fuel goes stale over the winter, if this is the 1st time its been used this season you will need to drain the gas and use fresh. it will be hard to start but if that is the issue it will start.
Posted on May 26, 2011
Troy Bilt pony riding mower, starts, runs for a short period then chokes out. Changed air filter, spark plug cleaned kill switch under seat, still does the same thing.
Check and probably replace fuel filter. Then carb will need to be cleaned/rebuilt. Sounds like the needle valve is sticking or the float is sticking.
Aug 09, 2016 | Troy Garden
Toto lawn mower wont start
Hi, do it have a spark plug
Sep 23, 2012 | Garden
Will crank over but will not start. i have replaced the spark plugs and fuel filter and cleaned the carburator. i dont know what else to do.
does it have spark? if so spray carb cleaner shot in carb and see if it will fire, also make sure you have power to your fuel solenoid in float bowl. my guess is the fuel solenoid(roll-over) is probably your problem..Good Luck 2StrokeJim
May 19, 2011 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
I have a briggs and stratton 158cc yard machine mower. I need to replace the spark plug and the air filter but I dont know what kind or size of spark plug I need nor do I know anything about hte air...
A champion cj 8 plug will work fine. As far as air filter it is probably a paper on, take the old one to a dealer or small engine repair shop and they can match it up for ya.
Oct 06, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
WILL NOT START
Ok...time to take her pulse then!
1. Does it have fuel? Look for water in fuel *(check gascan too!)
2. Does it have spark? You need to remove the plug and inspect it. do you see any oil, fuel or even water on the plug tip? You can plug in the sparkplug and dangle it near the metal part of the engine and confirm that the plug makes spark. If it doesnt get another one just to make sure the plug isnt fouled out.
3. Can the engine breathe? Remove the air filter and see if the filter is oil,water or fuel soaked. Is it rusty? Covered in dust, dirt, fuzz or fur?
You can check the engine once you are sure you have spark by putting a splash of fresh gas in the sparkplug hole before putting the plug back in and attempting to start it....leave the air filter off for now. You dont want a bad filter getting in the way right now. If it starts and runs you can put the air filter back on and try to start it....if it wont start....replace filter too!
Good luck and be careful!
Jun 28, 2010 | Briggs & Stratton 190cc 875 Series OHV...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
My lawn mower cranks but wont start I have
The magnets are fitted in the flywheel under the pullstart engine cover but i dont think thats your problem. It sounds more like fuel trouble. Remove and clean out the carb. and maybe renew the diaphram.
Sep 05, 2009 | Garden
I have a toro recycler lawn mower that was made in 2005 according to the sn. it wont start. we have tore it down to check everything but still nothing. It has spark. after pulling a few times we check the...
If you have spark and gas, it should start. The plug shouldn't be wet with gas, adjust the carbuerator fuel flow screw to reduce fuel to the engine. Use full choke to get it started
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
Honda EG 2200 Generator wont Start
First make sure that you have a spark; remove the spark plug and position it so that the threads are touching the engine frame. Pull the cord and check the plug for spark. If you have spark, put the plug back in.
Get some starting fluid and spray it into the air intake of the carbuerator. Try to start the engine. If it starts and then stops, that indicates that you have a fuel delivery problem. Clean the fuel filter.
May 31, 2009 | Honda Electrical Supplies
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
