Question about Vacuums
Dull noise and burning smell - Vacuums
    Master:
  • 956 Answers
You should not run item incase of fire until you have unit checked out. The cost of an appliance engineer is cheaper than replacing people and home should a fire start, remember, though switched off, if there is a faulty motor which may be causing the burning smell, it has been know to smolder and igninte in the cupboard.
Play safe, if you are not a DIYer let the professionals repair or pi passed its sell buy date replace, and have a retirement party for the retiring faithful ******!!
Posted on May 26, 2011
Burning smell and noise from vacuum
The roller head may be turning, but something could be rubbing and causing the belt to slip slightly. I'd remove the belt and beater bar and look for foreign material that is stuck
Jan 07, 2015 | Sebo ET-1 Powerhead White
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Riccar RSL4 Supra Lite Very Noise/Slight Burning Smell
I am looking for a new motor for my 8920 Ricaar Vacuum. Can you lead me in the right direction. I can put it in my self. I replace them before. I used Ricaar for 25 years. Love them
Jan 02, 2014 | Riccar Vacuums
Electrolux cylinder vacuum No suction and loud noise and smell of buring rubber
rollers are probably stuck the belt is burning check for restrictions in you hoses as well as in the vacuum as well if nothing else works a repairman
Jul 13, 2012 | Vacuums
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
Wet vac motor making noise and smells like burning
Hi I would suggest that the burning smell and the noise will mean that the motor is burnt out. You can get them pretty cheaply from the internet and they are quite easy to fit.
Mar 04, 2010 | Henry Numatic "" Canister Vacuum
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
