Question about HP DeskJet 3740 InkJet Printer
Prints only black
My printer does not print in colour though i have coloured ink installed
    Master:
  • 638 Answers
You must have turned your printer to "print in black mode only" by mistake.change the settings to "print in colour" in printer properties.
Posted on Aug 16, 2008
SOURCE:
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
Kodak 5300 printer: I just changed the black ink but it is printing as though there is no black ink. Ihave tries calabrating, cleaning, deep cleaning, etc. It says there is a full cartridge of ink.
From what i understand with the kyocera colour printers theres a menu option to print black as black opposed to a combination of the colours. I'm not too sure where it is, however it sounds like the kodak is very simular and is using the colours to create black instead of using the blank ink cartrage.
Jun 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Won't print in colour
In the Printer Settings you have to leave it as '"Print in Color" always not Black even if you want to print B&W.
Good Luck
luciana44
Dec 26, 2009 | Canon BubbleJet i560 InkJet Printer
One colour cartridge on epsom sx200 is empty yet it wont allow me to print in black only
umm... this is not a solution because I don't think there is one apart frombuying new inks. Epson and all other inkjet printers do this to preventthe coloured print head nozzles from getting blocked. If they are notused for a long time the ink dries up and blocks the nozzles. Epsonrecommends printingat least once a month with all colours to prevent this. Printing inblack only option will only work if the colored inks are OK. Wheneverthe printeris turned on it performs a head clean, this is why the coloured inksget used over time even though they are not used for printing.
www.Quikshiptoner.com
Nov 25, 2009 | HP LaserJet 2840 All-In-One Printer
HP deskjet 3420 won't print in black.
It's probably because the colour cartridge has run out, it needs a colour cartridge aswell to print black.
Aug 04, 2009 | HP Office Equipment & Supplies
Inks
Hi, Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. Unless you have selected "print in black & white only" your printer will "mix" the coloured inks with the black, also check the printer options to ensure you are not using the photographic quality as this will use inks very rapidly. You need to consider a couple of things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Jul 09, 2009 | Epson Office Equipment & Supplies
How to use only black cartridge on cx7450 epson !
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
Apr 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
There is no black ink in the printer but there is colour how do i get it to print
Depending on the type of printer you may be able to print all in colour instead of black/white. The easiest solution is to replace the black ink cartridge though.
Jan 14, 2009 | Office Equipment & Supplies
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
HP DeskJet 3740 InkJet Printer Logo
95 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
